Toymods » Tech & Conversions » 2tg excitement
kdogg
leumeah NSW
2tg excitement Tue, 03 May 2005 07:05 Go to next message
hey guys if i was to get a 2tg and do all the minor mods (3t crank new pistons bigger cams) and get it injected. would it be possible to run quad t/b's and a sc12 supercharger? Is it better to supercharge efi or carby? would i have to decompress the engine? oh by the way it will be going into a ke20.
EldarO
Perth, WA
Re: 2tg excitement Tue, 03 May 2005 07:25 Go to previous messageGo to next message
its better to supercharge efi.
if you want to run high amount of PSI, youd be wanting to decompress the engine.
however, im led to beleive that 8-9 psi is ok, since your running an sc12, they dont produce much psi above that amoune, 12-15 psi is the limit i beleive?
as for quad throttles, yes you can do it, but it has to be custom AFAIK, the 4age silver top throttle will work but youll need an adaptor plate to mate the ports to your engine.
Eldar.O.
pheonix83
Devonport Tasmania
Re: 2tg excitement Tue, 03 May 2005 10:30 Go to previous messageGo to next message
First,
DONT BOOST A STD ENGINE.
unless u know what u are doing, if u are asking this question, thne dont do it.
Second,
Injected is better, but carbies are easier.
To A Certain Degree.
many people will argue for either.
But it all depends on how much money u have.
styler
Re: 2tg excitement Tue, 03 May 2005 10:52 Go to previous messageGo to next message
well your ideas seem to be pretty far apart, not that they can't be done but its a lot of custom work $$ to bring them together, you are better off with a more simple setup. plenty of ideas on this website making loads of power.
YelloRolla
On your mum!
Re: 2tg excitement Tue, 03 May 2005 10:54 Go to previous messageGo to next message
boosting a standard engine that is in good nick is fine. I would recommend that you go EFI with a supercharger.
Boost versus static compression ratio is dependant on the cam timing (IE dynamic compression is the important factor here), and integral strength of the components used.
Celica_John
Re: 2tg excitement Tue, 03 May 2005 11:18 Go to previous messageGo to next message
I'd imagine it would be much easier to start with a 4agze to get what you want to do. quad t/b's wouldnt be easy but it'll be even harder on the 2tg i'd say.
pay someone a few hundred to mount a 4agze and save yourself building a 3tg hybrid.
that's my 2 cents anyways.
smitty1
Re: 2tg excitement Tue, 03 May 2005 19:42 Go to previous messageGo to next message
Would it be more practical to pull the turbo of a 3tg and then supercharge that? That way you would have all the injection hardware.
bunkyT18
Pilbara
Re: 2tg excitement Wed, 04 May 2005 04:39 Go to previous messageGo to next message
I dunno about more practical. You would be better off just putting a better turbo on a 3TGTEU. I'm guessing thats the motor you mean and not the hybrid 3TG? If you are talking about a hybrid 3TG then yep the 3TGTEU turbo manifold will definitely fit. I think that the 2TGEU injection intake manifold would fit too, seeing as how you are running a 2TG head on a hybrid 3TG.
[Updated on: Wed, 04 May 2005 04:40]
EldarO
Perth, WA
Re: 2tg excitement Wed, 04 May 2005 05:40 Go to previous messageGo to next message
smitty1 wrote on Wed, 04 May 2005 03:42
why would you even think of doing this?
the only good thing about superchargers is the lack of lag, youd be sacrificing power, for the sake of lag, which, in itself can be reduced significantly by using a smaller turbo, for example the t25 off an s13 silvia.
you must remember, that superchargers, while compressing air, and giving a better power output, also rob the engine of power in order to turn the compressor.
the end result of supercharging a former turbo engine may be that you end up with a power figure lower than that of an NA engine.
to cut a long story short.
you have an engine, you remove the turbo, and add a supercharger, this reduces the power output, because of two reasons, the supercharger cannot produce the same amount of PSI as a turbo, and the supercharger is using the engines power to turn the compressor to make more power.
whereas, if you leave the turbo on there, and upgrade, the management, injectors, turbo and add an I/C, youll receive a shitload more ponies, but at the cost of turbo lag, albeit minimal, depending on the type/size of turbo used.
to summarise FURTHER: turbo = good, supercharger = bad
hope this helps.
Eldar.O.
bunkyT18
Pilbara
Re: 2tg excitement Wed, 04 May 2005 05:56 Go to previous messageGo to next message
Um, I would not say that superchargers are 'bad'. It depends on the application of the blower and the tuning setup. The guy is just asking questions about stuff he don't know.
Just a thought, if you are s/charging or turbocharging a NA motor, the throttle response is not affected by 'lag' in the same way an all turbo motor is. The higher compression of a NA setup means that you will still get that throttle response. It just means the old NA motor gets a kick in the pants once the turbo kicks in. In applications with most NA turbo or supercharged conversion it's probably safe to say that a max boost of about 6 to 7 psi will be heaps and safe to run. Any more and you will be entering 'on the edge' world. At that boost range, a supercharger will not be much different to a turbo. If anything it may even be better cos you have that constant boost thing going on.
So, if the motor has readily available parts that suit then it will make sense to use them rather than busting arse trying to make a square peg fit a round hole (Hmmm sounds a little sus eh?). In this case the turbo option is the way to go.
It's all in the tuning. Thats how hondas running 10:1:1 compression can still be boosted cos they have very good aftermarket tuning packages available.
EldarO
Perth, WA
Re: 2tg excitement Wed, 04 May 2005 06:09 Go to previous messageGo to next message
youve completely misunderstood me...
im talking about the 3tgte, removing the turbo in favour of a supercharger (3tgze), im bemused as to why you would do this because, in all sense of the action, i cannot justify doing so.
why would you reduce power figures in order to reduce almost non-existant lag?
Eldar.O.
bunkyT18
Pilbara
Re: 2tg excitement Wed, 04 May 2005 06:26 Go to previous messageGo to next message
'sighs' no mate. I'm in agreement with you. Read my post again. And... I'm not doing the mod here, the other guy is. I just thought that it was fair to say superchargers were not 'bad' as such. Like I have said before in my last posts on this topic, if there are available OEM parts that will fit like the 3TGTE manifold then use em (thats what I'm doing to a 3TEU at the moment). Of course it's silly to supercharge a turbo motor. I thought from the dudes post he is talking about a hybrid 3TG motor.
EldarO
Perth, WA
Re: 2tg excitement Wed, 04 May 2005 06:49 Go to previous messageGo to next message
cool cool, as long as im right Razz
yeah, im looking at supercharging my 2tg/3t and it should be able to handle 7-8 psi, well, i should hope so, because thats what its getting!
i dont want to start having to rebuild it with forgies etc.
looking to do this near the end of this year though, can wait till im on holidays Very Happy
Eldar.O.
bunkyT18
Pilbara
Re: 2tg excitement Wed, 04 May 2005 07:05 Go to previous messageGo to next message
Ahhh yeh mate you are right Freak Nice to be secure innit? lol
Sounds wicked the charged 2t/3t! You better post some pics dude. I'll be posting my 3TEU pushrod turbo monster build when I get all my other car shit under control. Sorry for the thread hijack Y'all.
[Updated on: Wed, 04 May 2005 07:07]
smitty1
Re: 2tg excitement Wed, 04 May 2005 19:56 Go to previous messageGo to next message
EldarO
I wouldn't be doing this, but it seemed to line up with what kdogg was asking for more than anything else. Injected, 1.8, supercharged motor.
Ian
Dominic
Perth,western australia
Re: 2tg excitement Thu, 05 May 2005 02:09 Go to previous message
and as for supercharger vs turbo,
a good twin screw blower will give you the same amount (if not more) boost than a turbo,though out the entire rev range.(think 8psi from 1500rpm)
the fact that it uses power from the engine to turn is takin into account from the start so its not like your losing power.
and also,the supercharger will give you more torque low down.
this will give you better launchs etc.
but,the cost of a good twin screw supercharger is a bit more than a new or recon turbo i would think.
it all comes down to application and dollars.
one cannot be said to be good or bad in a general sense.
Dom
Previous Topic:20V spark plugs
Next Topic:rim offset diagrams
Current Time: Thu Oct 22 09:02:49 UTC 2026
Total time taken to generate the page: 0.022380113601685 seconds
