Classifieds » Car/Engine Electronics & Audio » Apexi S-AFC2 and Apexi S-ITC [BOTH SOLD]
Switch to threaded view of this topic Create a new topic
earthweb
Perth, WA.
Apexi S-AFC2 and Apexi S-ITC [BOTH SOLD] Tue, 03 May 2005 10:41 Go to next message
For sale:
Apexi Super Air Flow Converter 2 - SOLD
Apexi Super Ignition Timing Controller - SOLD
"Super ITC (Ignition Timing Control)
The Super ITC adjusts ignition timing by +/-15% by modifying the crank/cam angle signal on certain vehicles. The timing curve is adjusted by setting the timing at 5 different points along the RPM range and the values between are interpolated by the ITC from those 5 points. The Super ITC used in conjunction with the Super AFC fuel controller creates a new dimension of tuning with piggyback computers. Due to the complexity of this product, A'PEXi recommends having the Super ITC installed and tuned by authorized shops."
"Super AFCII (Air Fuel Controller)
The second-generation S-AFC is a fuel computer that adjusts fuel/air ratio by modifying the air-flow meter/MAP sensor signal. The S-AFC features a user-definable, eight-point, adjustable fuel curve that can be set in 500 RPM increments. The range of fuel adjustment is +/- 50% at each of the user-defined setting points. On hot-wire vehicles, the Deceleration Air Flow Correction function is capable of curing the erratic idle and stall problems associated with open-atmosphere blow-off valves on hot-wire air-flow meter systems. The S-AFC is capable of monitoring and replaying the following data channels in Numerical, Analog Meter and Graph displays: Intake Manifold Vacuum/Boost Pressure, Air Flow Capacity, Intake Manifold Pressure, Karmann Frequency, Engine RPM, Throttle Position, and Air Flow Correction %. Due to the complexity of this product, Due to the complexity of this product, A'PEXi recommends having the V-AFC and other A'PEXi electronics installed and tuned by authorized A'PEXi Power Excel Shops."
Chasing $600 with buyer paying for freight if you're outside of Perth.
Both items are fitted to my GZ20 Soarer and can be viewed working if you're in Perth. I can take them out anytime as I've currently got a blown head gasket.
- Chris.
http://www.tuningcar.kiev.ua/apexi/images/401A005.jpg
http://www.importscene.com.au/images/safc2.jpg
[Updated on: Thu, 12 May 2005 08:33]
2zz-ge power
April 2005
Re: Apexi S-AFC2 and Apexi S-ITC Wed, 04 May 2005 05:38 Go to previous messageGo to next message
Are you willing to seperate..
how much are you chassing for your SAFC-II
Greg
hamgatan
Re: Apexi S-AFC2 and Apexi S-ITC Wed, 04 May 2005 07:16 Go to previous messageGo to next message
Chris,
If you'll take 300 for the S-AFC ill pick it up off you tomorrow with Cash..
Regards
Chris S.
[EDIT: Actually DW Sorry, just picked one up for $250 shipped]
[Updated on: Wed, 04 May 2005 07:27]
earthweb
Perth, WA.
Re: Apexi S-AFC2 and Apexi S-ITC Thu, 05 May 2005 09:50 Go to previous messageGo to next message
Sorry 2ZZ-GE Power,
The SAFC2 is gone but I still have the Ignition Timing Controller, asking $200.
- Chris.
hamgatan
Re: Apexi S-AFC2 and Apexi S-ITC Thu, 05 May 2005 12:29 Go to previous messageGo to next message
drat... if only i had a little more $ this week Sad
might pm u next week abt it if i score some more cash..
[EDIT: Got my S-AFC from John @ ImportBitz Already]
[Updated on: Thu, 05 May 2005 12:33]
earthweb
Perth, WA.
Re: Apexi S-AFC2 and Apexi S-ITC Thu, 12 May 2005 08:34 Go to previous message
Both items are now sold Smile
- Chris.
Previous Topic:FS: Clarion screen [[SOLD]]
Next Topic:Boss Audio CD/MP3 player (cheap as chips!!!!) (PICS)!!
Current Time: Wed Oct 21 15:00:10 UTC 2026
Total time taken to generate the page: 0.0044839382171631 seconds
