Toymods » Tech & Conversions » head gasket on 4agze (stadard or copper)
tankrolla
cranbourne
April 2005
head gasket on 4agze (stadard or copper) Tue, 03 May 2005 11:35 Go to next message
hi all,
I have just bought a 4agze for my ae82 hatch and it has a blown head gasket,i was wondring if it is worth putting a copper headgasket rather then the standed.
I was planing to change the crank pully to a blitz one in a fue months.If anyone has changed the pullys or a friend has could you give me an idear on what is best
thanks!
ra_28
Re: head gasket on 4agze (stadard or copper) Tue, 03 May 2005 22:04 Go to previous messageGo to next message
Copper head gaskets are not good if you plan on not rebuilding the engine offten because the copper reacts with aluminum you don't want that. They can also be a hassle to fit you need to kneel the copper first so it goes soft if you want to run a good head gasket get a multiple layer steel head gasket there very good. HKS should make one.
BigWorm
Toymods Board Member
Turramurra, Sydney.
Re: head gasket on 4agze (stadard or copper) Wed, 04 May 2005 03:04 Go to previous messageGo to next message
Yeah there's a few aftermarket metal HGs available for the 4A, HKS prolly have the largest range in relation to different thicknesses, ranging from about .8mm to 2.0mm.
I picked up one for about $150.
After all that though, the standard GZE HG is a pretty good thing, and comes in under $100.
drift86levin
brisvegas
Re: head gasket on 4agze (stadard or copper) Wed, 04 May 2005 03:23 Go to previous messageGo to next message
hey, i got a Cometic 3 layer 1mm steel gasket, and it is excellent..cost $120 retail..and about $80 trade..
i would get the head checked for warpage just incase Very Happy
GTZLevin
Gold Coast/Brisbane/No wh...
January 2005
Re: head gasket on 4agze (stadard or copper) Wed, 04 May 2005 06:17 Go to previous messageGo to next message
what retailers on the coast or in brisbane stock HKS 4agze head gaskets???
am having mine rebuilt at the moment..
and after a full kit of gaskets.. not just the head gasket
ed_ma61
Lost in the K hole
Re: head gasket on 4agze (stadard or copper) Wed, 04 May 2005 06:24 Go to previous messageGo to next message
ra_28 wrote on Wed, 04 May 2005 08:04
i really suggest you folks do some reading on copper head gaskets
really
anyway - laminated stell is a much better option as suggested
[Updated on: Wed, 04 May 2005 06:26]
Dr_Love
January 2005
Re: head gasket on 4agze (stadard or copper) Wed, 04 May 2005 09:01 Go to previous messageGo to next message
i would also be interested in knowing where to get one of these hg's for the 2jz. autobarn should be good?
EVOSTi
cambo
      no
Re: head gasket on 4agze (stadard or copper) Wed, 04 May 2005 10:56 Go to previous messageGo to next message
autobarn arent good for anything.
Big T
Re: head gasket on 4agze (stadard or copper) Wed, 04 May 2005 12:51 Go to previous messageGo to next message
EVOSTi wrote on Wed, 04 May 2005 20:56
Laughing Laughing Laughing Laughing Laughing
Seriously though, Greenline stock HKS gaskets for the 2jz. They're not cheap though. I worked to out to be $380 or so for a stopper type metal hg. That's also NOT including shipping.
Eddie.
ra_28
Re: head gasket on 4agze (stadard or copper) Wed, 04 May 2005 23:46 Go to previous messageGo to next message
ED ma61 I think you should read these about coppr and aluminum just for starters.
http://www.finishing.com/131/28.shtml
http://www.dossert.com/technicalinfo/corrosion.htm
http://www.mckmetals.co.nz/aluminium-page2.asp
[Updated on: Thu, 05 May 2005 02:15]
Dr_Love
January 2005
Re: head gasket on 4agze (stadard or copper) Thu, 05 May 2005 01:48 Go to previous messageGo to next message
Big T wrote on Wed, 04 May 2005 22:51
Eddie.
Hory Shitte.
Is the difference worth that much cash? WTF does it do over and above a normal gasket? (excuse my ignorance)
HKS are always way overpriced too, surely there would be cheaper options that are just as good?
peeack
Re: head gasket on 4agze (stadard or copper) Thu, 05 May 2005 02:33 Go to previous messageGo to next message
You can use them to reduce compression for turboing an NA car, or for a turbo car I spose. Also, they'll hold up alot longer than a stock one, especially on 7M's Wink
How much HP are you pushing in your 2j? unless it's a huge ammount, I doubt' you'll 'need' to change it, but there is nothing wrong with erring on the side of caution. I've never heard anything bad about stock 1j/2j HG's.
EVOSTi
cambo
      no
Re: head gasket on 4agze (stadard or copper) Thu, 05 May 2005 06:31 Go to previous message
yeah im running a HKS metal headgasket, cant remember the thickness but it reduced the compression ratio which i also cant remember the figures for. its supposed to make it 'safer' to run more boost. my gze ran 15psi on the s/c for the most part of 10 years, and has been runing between 12-18psi for just over a year with the turbo. all is good, there may be a SLIGHT leak of oil from the HG if at all.
Previous Topic:18RG electronic ignition
Next Topic:2JZ-GTE gurus in Melbourne
Current Time: Mon Oct 19 15:50:01 UTC 2026
Total time taken to generate the page: 0.0073890686035156 seconds
