Toymods » Tech & Conversions » 4age cams
Da_RoNz
4age cams Wed, 04 May 2005 03:47 Go to next message
i did a search and couldnt find the answer im looking for.
My question is that whether or not there is a benefit in getting cams on a stockish motor, and whether or not it will make a difference.
Im thinking 250° with around 8mm of lift.
Will that be able to run on the stock ecu?
Any help would be appreciated.
drift86levin
brisvegas
Re: 4age cams Wed, 04 May 2005 04:15 Go to previous messageGo to next message
it should be fine with the stock ecu..is it big port or small port?? AFM or map? map sensors might have a bit of trouble idleing..but the air flow meter should be fine (minor adjustment)
rxjohn
Melb VIC
Re: 4age cams Wed, 04 May 2005 04:18 Go to previous messageGo to next message
250 duaration and 8mm lift aint that big, std big port cams are 240 & 7.6mm lift, only small gains, yes will run with std ECU, if you go for somthing bit bigger like 270deg , with exhaust, higher compression etc will start to see power difference
Da_RoNz
Re: 4age cams Wed, 04 May 2005 05:32 Go to previous messageGo to next message
the engine is a smallport MAP version.
drift86levin
brisvegas
Re: 4age cams Wed, 04 May 2005 05:46 Go to previous message
should be fine..
your stock cams are 232 dur and 7.1mm lift..i noticed a small difference in mine when i put big port cams in 240 and 7.6... so you should notice a good difference..don't forget to check all your shims!!
Previous Topic:B.O.V. plumback restriction
Next Topic:How to set timing on 4AGTE with coil packs?
Current Time: Wed Oct 28 06:12:57 UTC 2026
Total time taken to generate the page: 0.0039148330688477 seconds
