Toymods » Tech & Conversions » How to set timing on 4AGTE with coil packs?
papercut
How to set timing on 4AGTE with coil packs? Wed, 04 May 2005 04:15 Go to next message
hi guys
haven't seen this one really covered, but i just had the NRMA come round to check out my car
recently my 4agte celica has started pinging, until the other day it started to backfire and hesiate at low gear, and eventually all gears.
It is definately timing, but i am unsure of how to set it without a distributor.
anyone can give me a step by step?
it's a series 2 4AGZE. coilpacks, crank angle sensor, AFM
4agte
Toronto, Downtown
Re: How to set timing on 4AGTE with coil packs? Wed, 04 May 2005 04:19 Go to previous messageGo to next message
from memory you can change the base timing by adjusting the crank angle sensor.
papercut
Re: How to set timing on 4AGTE with coil packs? Wed, 04 May 2005 04:23 Go to previous messageGo to next message
how do i adjust it that way?
would it be the same as a TPS? just unscrew and rotate the gear?
gearb0x
Re: How to set timing on 4AGTE with coil packs? Wed, 04 May 2005 04:25 Go to previous messageGo to next message
Its just like rotating a dizzy
the CAS is practically the bottom half of a dizzy with a cap on it, just loosen the bolts that hold the CAS in and twist as u would a dizzy
papercut
Re: How to set timing on 4AGTE with coil packs? Wed, 04 May 2005 04:33 Go to previous messageGo to next message
oh ok
so it's bascically trial and error?
would this be the only thing i can do to set the timing right?
4agte
Toronto, Downtown
Re: How to set timing on 4AGTE with coil packs? Wed, 04 May 2005 04:38 Go to previous messageGo to next message
get a timing light
drift86levin
brisvegas
Re: How to set timing on 4AGTE with coil packs? Wed, 04 May 2005 04:40 Go to previous messageGo to next message
there will be a little box that says diagnostic or something like that, and you need to bridge T1 and E1 (diagram under the cap) with a paper clip, or little bit of wire..which will disable the advance/retard on the timing..thus letting you adjust the base timing..books suggest 10deg..but you can get up to 12-13deg befor you have any dramas..
papercut
Re: How to set timing on 4AGTE with coil packs? Wed, 04 May 2005 04:44 Go to previous messageGo to next message
is that just temporary while you adjust the CAS?
Spanktown
Inside a giant turbo (syd...
Re: How to set timing on 4AGTE with coil packs? Wed, 04 May 2005 04:57 Go to previous messageGo to next message
yes
papercut
Re: How to set timing on 4AGTE with coil packs? Wed, 04 May 2005 05:00 Go to previous messageGo to next message
hmm just went down to find this 'box'
its not the fuse box is it? if not, then is it on the CAS?
Spanktown
Re: How to set timing on 4AGTE with coil packs? Wed, 04 May 2005 05:02 Go to previous messageGo to next message
on my aw11 mr2, its on the back firewall, its about 1.5cm by 2.5 cm rectangle little box that says diagnostic on it. I have no idea where it would be in your car.
papercut
Re: How to set timing on 4AGTE with coil packs? Wed, 04 May 2005 05:04 Go to previous messageGo to next message
ta i'll give it a shot now.
so this would only be effective while the car is running?
also, how do i know how many deg. timing?
[Updated on: Wed, 04 May 2005 05:05]
Spanktown
Re: How to set timing on 4AGTE with coil packs? Wed, 04 May 2005 05:21 Go to previous messageGo to next message
i wouldnt go twisting it willy nilly and driving it, i would get a timming light, and actually know what your doing. Failing that, take it to a mechanic that can do it for you.
ra23celica
Re: How to set timing on 4AGTE with coil packs? Wed, 04 May 2005 05:25 Go to previous message
Buy a timing light.
Clip the red clip on the positive battery terminal.
Clip the black clip on the negative battery terminal.
Clamp the other do-hicky onto number one plug lead.
You want the diagnostic port in the engine bay. A diagram of the pins will be inside underneath its lid.
Bridge T1 and E1 with a wire.
Start engine.
Point flashing light at timing marks on timing chain/belt cover, just above crankshaft.
Watch for notch in crankshaft to come whizzing past and show you where the timing is currently.
Loosen the CAS, rotate it slowly until you get the timing set at the 10 degree mark (BTDC). Don't worry about advancing it, the factory manual says 10 degrees, leave it there.
Pull the bridging wire, test that the spark advance system works by revving the motor and watching the timing.
Don't trial and error this.
[Updated on: Wed, 04 May 2005 05:26]
Previous Topic:4age cams
Next Topic:1UZ soarer conversion
Current Time: Wed Oct 28 18:03:03 UTC 2026
Total time taken to generate the page: 0.0051479339599609 seconds
