Toymods » Tech & Conversions » cooling problems ae86
.wolfwood
Gold Coast
February 2005
cooling problems ae86 Wed, 04 May 2005 08:43 Go to next message
hey all i have 4agze with turbo conversion i live in qld, it got goot frount mount but i cantdrive car in day cuz of heat, the car runns at 80 degrees average but gets a shit load hotter in lower gears and during the day, ay one got some suggestions? i think is the radaitor but not sure help me plz.
FKN16V
NSW, East Coast
Re: cooling problems ae86 Wed, 04 May 2005 12:06 Go to previous messageGo to next message
wat sorta radiator you using, what sorta fan you using (thermo or belt)
Information rules.
Steve
drift86levin
brisvegas
Re: cooling problems ae86 Wed, 04 May 2005 12:37 Go to previous messageGo to next message
thats weird..my stock radiator was fine..but anyway..go down to your local wreckers..grab a nissan urvan radiator (pretty sure thats what it's from) and chuck it in..it fits in nicly with 2 brakcets on the side, and it has 3 fat cores of goodness!!
optionUP
Perth, WA
Re: cooling problems ae86 Wed, 04 May 2005 13:42 Go to previous messageGo to next message
You might want to consider an oil cooler.
By the way, how much hotter does the water temp get than 80 degrees?
My 4AGTE runs between 90-93 degrees (this is reading off the Wolf hand set controller) without any problem. This translates to halfway on the dash temp gauge, and it stays there summer and winter long.
allencr
tallahassee FL usOFa
Re: cooling problems ae86 Wed, 04 May 2005 13:54 Go to previous messageGo to next message
what's wrong with 80 degrees???
that's below normal.
.wolfwood
Gold Coast
February 2005
Re: cooling problems ae86 Wed, 04 May 2005 16:02 Go to previous messageGo to next message
its stays around 80 to 90 when driving in 4th or want not but in seconds and aht it does up over 170 and tahts not cool. its stock radaitor i think.
+ its belt fan
[Updated on: Wed, 04 May 2005 16:03]
driftae86
perth
Re: cooling problems ae86 Sat, 07 May 2005 16:40 Go to previous messageGo to next message
get electic fan...more efficient.
plus, get a fatter radiator. and maybe a vented bonnet Razz
you havent got air con do you?
but if it gets really hot only at certain times then airflow may not be the problem. Confused
ae95
Re: cooling problems ae86 Sat, 07 May 2005 19:59 Go to previous messageGo to next message
have you checked the condition of the core
i've seen lots of ae86's with a lot of corroded fins
IRA11Y
Club Member
Re: cooling problems ae86 Sat, 07 May 2005 23:02 Go to previous message
well if it gets as low as 80 when your driving it would have to be bloody cold outside seeing as the standard thermostat opens at 82c, general operating range should be between 84-90cish.
With the Wolf I also sit around the 90c mark but because of the size of my radiator i can drop as low as 86c and i set thermos to kick at 95c ( never gets there unless im sitting stationary for more than 10 mins in hot conditions ). Ive often wondered if the Wolf reads slightly high but have never got around to throwing the temp probe in there, also i measure my temp from the back of the head where the temp is slightly hotter anyway so it could well be accurate.
[Updated on: Sat, 07 May 2005 23:04]
Previous Topic:AE86 with T18 diff, LSD installation
Next Topic:Powerful TA22 engine
Current Time: Thu Nov 19 10:36:32 UTC 2026
Total time taken to generate the page: 0.0069310665130615 seconds
