Toymods » General Car Talk » front drive dragging
kewp
wollongong
front drive dragging Wed, 04 May 2005 11:46 Go to next message
What are some things you can do to make a front wheel drive launch better off the mark? My corolla is very slow off the mark, even for a FWD
boog
campbelltown
April 2005
Re: front drive dragging Wed, 04 May 2005 11:50 Go to previous messageGo to next message
Very Happy learn to drive a fwd Razz
what is the suspension setup like ???? it all comes down to throttle to clutch ratio you realy have to learn what your car wants every car is different. good luck , try to experament more like just redlin e it and drop it then go back from there till your happy.. thats how i done it. when you get it right its a good feeling
Fr3aK
Wollongong
January 2005
Re: front drive dragging Wed, 04 May 2005 11:51 Go to previous messageGo to next message
In my car i wish i had really stiff springs. This would stop the weight transition.
When people drag FR cars, they like to fit 90/10 shocks. I wonder if 10/90's would be suitable for FF drag?
Other than that, fit wide-arse tyres and give it plenty of revs.
rthy
Melbourne - NthSubs
Re: front drive dragging Wed, 04 May 2005 13:03 Go to previous messageGo to next message
bigger front tyres, i lol when i see a fwd with bigger rear tyres
ie. 185 at the front with 195 at the back on a civic Laughing
4agte
Toronto, Downtown
Re: front drive dragging Wed, 04 May 2005 13:04 Go to previous messageGo to next message
wheely bars help to stop the weight transition but then its not really a street car anymore
smashed_wombat
Re: front drive dragging Wed, 04 May 2005 13:45 Go to previous messageGo to next message
I read that Whiteline make anti-lift kits for FWD cars to reduce the weight transfer rearward on launch. Side effect is that the car will tend to dive more when braking. Probably not recommended unless you're building a specialised drag racing car?
allencr
tallahassee FL usOFa
Re: front drive dragging Wed, 04 May 2005 13:47 Go to previous messageGo to next message
sorry, can you give me a clue. is this about engine power, or wheel/s spin, or clutch slip, or launch style/technique.
kewp
wollongong
Re: front drive dragging Thu, 05 May 2005 00:01 Go to previous messageGo to next message
allencr wrote on Wed, 04 May 2005 23:47
It's slow because it gets hardly any traction. And i've tried every technique for getting it off the mark. In my friends integra you can dump the clutch from 6000rpm and it only wheelspins a little bit then grips hard and accelerates. He can pull 2 car lengths on me just off the launch. In my car if you drop the clutch from 3000rpm it will just sit there and smoke the front wheels. You have to be so careful letting the clutch up not to start spinning.
I know FWD cars don't launch very good at the best of times but my car is seriously bad. It only has stock suspension and wheels at the moment, what would be the best value mod i can do to improve traction? Would wider front tyres and stiffer rear springs help?
Corona RT142
Campbelltown
Re: front drive dragging Thu, 05 May 2005 00:09 Go to previous messageGo to next message
what type of corolla do you have, cause unless its a new sportivo or a very worked 4age, the type R will still woop you to start off with, ten bucks says the type R has much better front tyres for a start and suspension.
Look into better shocks springs etc, these help keep the wheel in contact with the road, and stiffer springs will help to stop the weight transfer, after that if whiteline make an anti lift kit try that. Personally though why are you racing a type R
ke382TG
Re: front drive dragging Thu, 05 May 2005 00:18 Go to previous messageGo to next message
Sounds like it's making about 923 newton metres of torque from 1830rpm and has the handbrake on Very Happy Very Happy Very Happy
Seriously though, some nice grippy tyres will make an enormous difference. You may need to slip the clutch a tad instead of just dropping it. That way you will get the car moving instead of just breaking traction and trying to regain it.
[Updated on: Thu, 05 May 2005 00:19]
st184 sillycar
Re: front drive dragging Thu, 05 May 2005 01:14 Go to previous messageGo to next message
New front shocks, properly matched to the springs will make an enormous difference. Wide, soft tyres will have obvious benefits.
In the Celica, I found I had to slip the clutch at the tyre's traction limit, until the front had risen as far as it was going to. Only then could I let the clutch fully engage (slight chirp) and proceed to feed the throttle in.
I couldn't tell you what sort of revs at what point in the process - It's ALL feel. You'll know it when you've got it: no wheelspin, minimum chirping, Engine stepping cleanly straight from the clutch-slip into the start->middle of it's Torque band.
Very satisfying, very quick (relative to a messy start).
Use less revs and less throttle, and you can nail the same kinda start in the wet too. Very Happy
buck naked
Re: front drive dragging Thu, 05 May 2005 01:16 Go to previous messageGo to next message
Corona RT142 wrote on Thu, 05 May 2005 08:09
And a LSD.
cycleofabuse
Re: front drive dragging Thu, 05 May 2005 01:26 Go to previous messageGo to next message
For starters just get some awesome tyres.
ke382TG
Re: front drive dragging Thu, 05 May 2005 01:32 Go to previous messageGo to next message
"Bob Jane all-rounders" spring to mind Laughing
Fr3aK
Wollongong
January 2005
Re: front drive dragging Thu, 05 May 2005 01:44 Go to previous messageGo to next message
When i first got my car it had 205/65/R15 family BS tyres on it. You could never use full throttle in first gear, or you'd sit there and spin the wheels, no matter if you were rolling or whatever.
So then i bought 225/60/R15 Potenza GIII's. It was really difficult to get wheelspin with these on. Only problem was, they wore out in 19 k's.
If you're deadset about dragging your standard rolla, just 'over tyre' it.
Aust162
Melb, Victoria
Re: front drive dragging Thu, 05 May 2005 02:14 Go to previous messageGo to next message
Did i miss something.. where did he say he was racing a Type R? Confused
Mate, just get some decent tyres first off and then look at your suspension.what type of corrola is it and what motor do you have?i find it hard getting off the line in my fwd turbo, but i just got new tyres and it made a massive difference,as expected. Smile
kewp
wollongong
Re: front drive dragging Thu, 05 May 2005 05:19 Go to previous messageGo to next message
Corona RT142 wrote on Thu, 05 May 2005 10:09
It's not a type R, it's an '86 integra SX 16 with 63kw @ wheels.
My car is an AE82 20v, I can absolutely kill him in acceleration when i get moving, but can't keep up off the start.
What size rims do i need for 225/60/R15 Potenza GIII's
At the moment i have crap tyres and 14 inch rims.
Also has anyone had experience with the Whiteline handling package for like $1500 Is it worth it or is it a waste of money?
Corona RT142
Campbelltown
Re: front drive dragging Thu, 05 May 2005 05:27 Go to previous messageGo to next message
probably nat rim with a width of 6.5 to 7 inch to get that rubber on.
ke382TG
Re: front drive dragging Thu, 05 May 2005 05:35 Go to previous messageGo to next message
A 15" rim would be a good start Very Happy the rim would ideally be 7" or wider for a 225 (7 or 8 inch is about right. Pretty sure it would be a struggle to get a 225 wide tyre under the guard of an AE82.
There are plenty of nice grippy tyres on the market that would fit your 14" rims in about a 195 width. 15" would have more available but I am assuming you aren't after a new set of rims?
Even just some newer tyres will probably make a big difference as old tyres harden and lose grip too.
Fr3aK
Wollongong
January 2005
Re: front drive dragging Thu, 05 May 2005 07:25 Go to previous messageGo to next message
You probably don't want 60 profile 15" tyres on your Corolla.
Find out what your stock overall rolling diameter is (so you don't change the speedo readings) and then find a GIII in that size.
I'm guessing a 205/60/R14 would be good for you. But your stock rims might not be wide enough. In that case, go the 195/60/R14's.
PLEASE keep in mind the GIII's wear out fast! And they are expensive.
BTW, i had my 225's on a 6inch rim. Not ideal, but they did fit.
screech
Wollongong
February 2005
Re: front drive dragging Thu, 05 May 2005 08:08 Go to previous messageGo to next message
i dont know how hard your car goes but you may also want to think about the drivetain.
My sisters b/f has a 10sec Honda Civic, it is equipped with wheelie bars, big slicks under flared guards, stripped interior and a very radical anti-lift kit. lots and lots of power also helps though.
but by far his biggest problem is the CV shafts. launching a FWD without spinning places huge strain on them. causing a very early bang munch pull over f@#k shit f*%k.
i think a change of tyres would be the best upgrade without going to extremes of body mods.
kewp
wollongong
Re: front drive dragging Thu, 05 May 2005 09:35 Go to previous messageGo to next message
I don't think i have to worry about breaking CV joints yet with the massive torque of the 20v behind them (not)
At the moment i only get about 3-4000k's out of a set of front tyres Smile Surely they would last longer than that, and they won't spin as much so they can't wear out as quick.
strober
Re: front drive dragging Thu, 05 May 2005 10:45 Go to previous messageGo to next message
It sounds like you need practice at throttle control.
I don't know if it's quicker but try different techniques instead of the clutch dump from 3000rpm.
Put your car in gear, hand brake up. Hold the revs up to I don't know... say 1500 - 2000 RPM. Slowly release the clutch and feel the friction point where the car wants to move but the hand brake holds it. When you launch drop the hand brake, gradually release the clutch while you gradually increase the throttle. Gradually ie in ratio, not just flooring or dumping anything.
It should feel like being launched from a slingshot but alas, different engines have different characteristics and this might not be the technique for you.
This would reduce the life of your clutch substancially but what you decide to do to your car is your business.
Hope you find this post of help
domasik
Re: front drive dragging Sat, 07 May 2005 01:14 Go to previous messageGo to next message
lightened flywheel, heavy duty clutch, sticky as shit front tyres, good suspension setup around, talk to whiteline, i know they make castor kits for AE92 but im not sure about AE82. if ur running 17's itll affect ur acceleration so somethng like 15inch would be good. try to find the right amount of revs u get the quickest launch, remember ull launch faster if ur tyres arent breaking traction cause when ur doing that there is less force pushign ur car in a forwards direction.
BTW: rthy is u ever come to sydney theres something id like to show u is possible in aa FWD car that contradicts ur comments.
[Updated on: Sun, 08 May 2005 05:16]
Celica_John
Re: front drive dragging Sat, 07 May 2005 01:21 Go to previous messageGo to next message
this is off the track a lil but i was reading a review on the peugeot 306 gti's and they said that the best way the figured out to get it off the line is to redline it and dump it lol - poor drive train Sad
domasik
Re: front drive dragging Sat, 07 May 2005 02:26 Go to previous messageGo to next message
yea my dad and the S16 version (only 5speed and slighly less power 116kw as apposed to 123kw) and redline is like 9000rpm if u wana push it
86DRFT
Rockhampton QLD
Re: front drive dragging Sat, 07 May 2005 09:40 Go to previous messageGo to next message
maybe your rear brakes are sticking? Laughing
4agte
Toronto, Downtown
Re: front drive dragging Sat, 07 May 2005 09:54 Go to previous messageGo to next message
kewp wrote on Thu, 05 May 2005 19:35
my mate has a 20v aw11 and he has destroyed 3 cv`s so far so its something to worry about
Arch
Re: front drive dragging Sat, 07 May 2005 09:58 Go to previous messageGo to next message
domasik wrote on Sat, 07 May 2005 10:44
remember ull launch faster if ur tyres are breaking traction
riiiight Rolling Eyes
domasik
Re: front drive dragging Sun, 08 May 2005 05:15 Go to previous message
ARENTTTTTTTTTTTT
i left out the TTTTT sorrryy
cmon im not that stupid geeez
Previous Topic:looking for SX burnout video on this site???
Next Topic:help me, weird problem :S
Current Time: Sun Nov 22 04:37:09 UTC 2026
Total time taken to generate the page: 0.00872802734375 seconds
