Toymods » Tech & Conversions » Toyota oil pressure senders.
smashed_wombat
Toyota oil pressure senders. Wed, 04 May 2005 13:40 Go to next message
Does anyone know if its possible to get an oil pressure sender that's smaller than the 3S-GE Gen I type? I went to swap it over to my new motor but it fouls on the throttle body and water outlet bolts. Any ideas? Is it possible to get an extension welded up to it? Bit peeved that I cant use the stock Oil Pressure Gauge...
Re: Toyota oil pressure senders. Wed, 04 May 2005 14:21 Go to previous messageGo to next message
Go to a hydraulic shop. Ask for a variety of angles or extensions to suit. Purchase. Fit. Feel the love.
TA-022
Glenmore Park, NSW
Re: Toyota oil pressure senders. Wed, 04 May 2005 20:44 Go to previous messageGo to next message
Quote:
feel the love
Laughing
can these senders be used with aftermarket pressure guages (electrical) say on a 18rg as long as i get it to fit?
/sorry for hijack
Nathan
styler
Re: Toyota oil pressure senders. Wed, 04 May 2005 22:11 Go to previous messageGo to next message
if you get one that is the correct output range yes, try vdo website for their collection of senders in different ranges.
smashed_wombat
icon14.gif  Re: Toyota oil pressure senders. Thu, 05 May 2005 09:22 Go to previous messageGo to next message
GT, thanks mate. So should I try a place like Pirtek? I'll check the yellow pages. I can almost feel the love already! Smile
Re: Toyota oil pressure senders. Thu, 05 May 2005 09:34 Go to previous messageGo to next message
gianttomato wrote on Wed, 04 May 2005 22:21
Profit
And yes, Pirtek, Enzed, anythere that sells fittings.
EVOSTi
cambo
      no
Re: Toyota oil pressure senders. Thu, 05 May 2005 09:39 Go to previous messageGo to next message
baha profit Laughing Laughing
yeah just put a 45 degree elbow in the block and screw the sender into that. or if your really short on space you could put a barbed fitting in the block and run a hose to the sender somewhere else. then you just have to run an earth wire to the sender.
takai
Re: Toyota oil pressure senders. Thu, 05 May 2005 10:03 Go to previous messageGo to next message
Seriously i would run a hose somewhere else. Having adaptors snap off in the block is NOT fun.
smashed_wombat
Re: Toyota oil pressure senders. Thu, 05 May 2005 10:25 Go to previous messageGo to next message
Yeah, true.. Just for clarity I thought I should post some pictures. The sender screws into a threaded hole on the side of the head.
Sender switch:
http://members.optushome.com.au/an-d/web/2/switch1.jpg
Old pressure sender:
http://members.optushome.com.au/an-d/web/2/sender.jpg
The bits circled in red are where the sender fouls:
http://members.optushome.com.au/an-d/web/2/switch2.jpg
I thought it might be possible to cut off the black tab on the right in the pic, but it would still foul on the bolt for the water outlet. It only need to be extended 15mm or so to thread into the hole, that should be fairly safe shouldn't it?
EVOSTi
cambo
      no
Re: Toyota oil pressure senders. Thu, 05 May 2005 10:54 Go to previous message
yeah i think so, you prob wouldnt even need a bend just an extension.
Previous Topic:injectors 4age
Next Topic:4age quick question
Current Time: Thu Oct 22 10:50:07 UTC 2026
Total time taken to generate the page: 0.0050451755523682 seconds
