Toymods » Tech & Conversions » Aftermarket Cams for 3sge!!! After mild setup
TRD-ST162
Aftermarket Cams for 3sge!!! After mild setup Wed, 04 May 2005 13:49 Go to next message
I've got a gen 1 3sge.
I'm just wondering what the standard duration might be and what I might be able to go on the standard ecu. And how would the powerband change?
It peaks power at 6000..
What sort of gains could be had?
Thanx again!!!
acreese
Re: Aftermarket Cams for 3sge!!! After mild setup Wed, 04 May 2005 14:07 Go to previous messageGo to next message
http://forums.toymods.org.au/index.php?t=msg&t h=62131&rid=5822&S=0df576c1d9f29d0329bfdc4 66289aaac&pl_view=&start=0#msg_572496
Dude, you already asked this ^ ^ ^
thats your last thread asking the same thing, there are about 5 genuine answers in there already.
Custom cams, or expensive TRD items to quote just two of them.
If you are not happy with the answers, bump your old thread up so at least people can see the history and dont repeat what they have said prior.
Adam
Re: Aftermarket Cams for 3sge!!! After mild setup Wed, 04 May 2005 14:13 Go to previous messageGo to next message
Standard ecu = standard cams.
TRD-ST162
Re: Aftermarket Cams for 3sge!!! After mild setup Thu, 05 May 2005 00:20 Go to previous messageGo to next message
My question was more surrounded about the standard duration of these cams would be, not about what could be upgraded to.
And what sort of gains..
I was happy with those answers, but these are different questions..
I haven't said anything thats been previously answered! They are different questions...
acreese
Re: Aftermarket Cams for 3sge!!! After mild setup Thu, 05 May 2005 01:21 Go to previous messageGo to next message
I conceed. Razz
as stated previously, standard ecu is a limitation.
If you have not already, Sponsor the ST162 Megasquirt and spark development and you will be able to go nuts. Contact RWDBoy for more details, go here...
http://forums.toymods.org.au/index.php?t=msg&t h=66725&rid=5822&S=0df576c1d9f29d0329bfdc4 66289aaac&pl_view=&start=0#msg_626072
That will sort you out Smile
Adam
Joshstix
Toymods Vice President
Re: Aftermarket Cams for 3sge!!! After mild setup Thu, 05 May 2005 04:10 Go to previous messageGo to next message
Basically nobody makes aftermarket cams for the Gen 1. They use a much smaller base circle and also a smaller bucket which limmits the amount of lift and duration you can put into a cam.
The only people I know who are doing aftermarket cams for the Gen 1 are http://www.atsracing.net/cams.htm.
I do not endorse their product in any way, I'm just letting you know it exists.
CelicaRA45
nth ringwood, Victoria
Re: Aftermarket Cams for 3sge!!! After mild setup Thu, 05 May 2005 11:56 Go to previous messageGo to next message
toda still make cams for st162 about 500 each these are billets and are for shim on top ,they also make some cams with shim under as well they are dearer ,but can get 256 dur 264 ,272, 288,and 304 lift ranging from 7.9mm to 8.5mm
TerryOBeirne
Redbank Plains,near Ipswi...
Re: Aftermarket Cams for 3sge!!! After mild setup Mon, 09 May 2005 12:19 Go to previous message
I've got a "mild" TRD set in a GpA head, out of a TTE rally GT4. you will never get the best performance out of any aftermarket cam without an ECU change.
Previous Topic:fly cutting 3tc forged pistons to suit 3tgte head
Next Topic:7mgte keep blowing HG, any help???
Current Time: Sat Oct 17 15:30:04 UTC 2026
Total time taken to generate the page: 0.0049591064453125 seconds
