Toymods » Tech & Conversions » incredibly soft brake pedal
jesseT18
Castle Hill, Sydney
incredibly soft brake pedal Thu, 05 May 2005 07:46 Go to next message
ever since i got my car put back together and running the brake pedal seems to be a hell of a lot softer than usual, you could get the brakes on full lock with a couple fingers... Confused
it brakes as good as usual, and all 4 wheels are locking up alright, its just REALLY soft!
i dont think its a leak or air in the system because usually your car wont brake as well with these would it?
im out of ideas, thinking about rebuilding booster and master but just wonmdering if anyone has been through this before or has any ideas what might be going on?
thanks, jesse
Re: incredibly soft brake pedal Thu, 05 May 2005 08:27 Go to previous messageGo to next message
A light brake pedal means it has lots of braking assistance, ie the booster is working well. Maybe your booster wasn't hooked up properly before, and you got used to a mega-hard pedal?
jesseT18
Castle Hill, Sydney
Re: incredibly soft brake pedal Thu, 05 May 2005 08:30 Go to previous messageGo to next message
yeah it used to feel more like it does when the engine isnt running and theres no vacumn to the booster.
so the chance of that vacumn hose being blocked before is possible
EVOSTi
cambo
      no
Re: incredibly soft brake pedal Thu, 05 May 2005 08:34 Go to previous messageGo to next message
its probably air in the system. your brakes will still work and lock up as normal, just a softer pedal. bleed the brakes, i mean it costs you $10 at most for fluid.
jesseT18
Castle Hill, Sydney
Re: incredibly soft brake pedal Thu, 05 May 2005 08:44 Go to previous messageGo to next message
bled them already, twice!
jesseT18
Castle Hill, Sydney
Re: incredibly soft brake pedal Thu, 05 May 2005 08:45 Go to previous messageGo to next message
if the vacumn hose to the brake booster was exposed/leaking what effect would that have on the pedal?
softer/harder?
EVOSTi
cambo
      no
Re: incredibly soft brake pedal Thu, 05 May 2005 09:30 Go to previous messageGo to next message
harder. and possibly poor engine idle, if the car has AFM.
did you bleed in the correct order?
M.J.H
Re: incredibly soft brake pedal Thu, 05 May 2005 09:37 Go to previous messageGo to next message
Did you bleed the master cyl first or just do it at the wheels?
If new pads /shoes fitted it could just be that they need to bed in.I know the pedal feels like shit in my car till the new pads bed in.
EVOSTi
cambo
      no
Re: incredibly soft brake pedal Thu, 05 May 2005 10:07 Go to previous messageGo to next message
yeah that can do it, but would go away after a bit of driving. another thing: i dont know what brakes you got but if you have drums on the rear, they may need adjusting. this wont make the pedal soft or spongy, but would make the pedal need to travel a bit before the brakes work. maybe this is your problem and your mistaking pedal travel for a soft pedal.
muaythaiman
Re: incredibly soft brake pedal Thu, 05 May 2005 11:07 Go to previous messageGo to next message
I had troubles with the twin carb manifold. If you run your vaccuum hose to one single entry point on the manifold, and say don't use those spacers with the gap that stabilises the air between the two carb throats, there is less vaccuum. I don't run those spacers and found the pedal is hard, and put it down to only relying on one throat to provide assistance to the booster. Maybe something has changed for you in the interim that has given you better vaccuum assist?
jesseT18
Castle Hill, Sydney
Re: incredibly soft brake pedal Thu, 05 May 2005 11:42 Go to previous messageGo to next message
sorry i should have given more info about my setup in the first post
its the stock brake booster, a corona master cylinder, commodore front brakes, R31 skyline reae brakes
its running off twin carbies on the stock vacumn connection to the 2tg manifold.
the only other thing i can think that has changed in that area is i fixed the cam timing, its idleing HEAPS better now than it ever used to, but the problem isnt just at idle but all through the rev range.
its brakeing really dam well, it could have just been heaps hard before and its right now, but ive had second opinions and everyone thinks the brakes are REALLY light and touchy.
another thing is the booster and master were sitting in the weather for a couple weeks while i was spraying the engine bay
the balance pipe from ports 1+2 and 3+4? im running one of them
[Updated on: Thu, 05 May 2005 11:44]
EVOSTi
cambo
      no
Re: incredibly soft brake pedal Thu, 05 May 2005 11:51 Go to previous messageGo to next message
well poor timing previously MAY have something to do with it, giving you insuficient vacuum in the manifold meaning a hard pedal.
muaythaiman
Re: incredibly soft brake pedal Thu, 05 May 2005 12:12 Go to previous messageGo to next message
Yeah. If your saying it's quite touchy and light I'd say the booster is alot more effective now than before. It could be what EVO said, and have something to do with timing maybe? (whether this would have much effect on the amount of vaccuum I don't know) Or what you said about it sitting around and the booster has just fixed itself or something..........stranger things have happened. I have heard huge numbers for getting boosters reconditioned, I looked into it as I said I had the same problem, atleast yours is good now.....
Re: incredibly soft brake pedal Thu, 05 May 2005 14:04 Go to previous messageGo to next message
Cam timing has a big influence on manifold vacuum at idle. Sidedraught carbs have poor vacuum to begin with, but with the cam timing out there would have been bugger-all.
muaythaiman
Re: incredibly soft brake pedal Thu, 05 May 2005 14:08 Go to previous messageGo to next message
Well there you go! Now I know what's wrong with mine. I was going to get the cam timing done soon anyway. Thanks Norbie!
M.J.H
Re: incredibly soft brake pedal Fri, 06 May 2005 03:31 Go to previous messageGo to next message
jesseT18 wrote on Thu, 05 May 2005 21:42
Maybe the master cyl is the wrong size for the calipers and this has only shown up with the right manifold vacum.
pclabrat
Re: incredibly soft brake pedal Fri, 06 May 2005 10:12 Go to previous messageGo to next message
I'm not sure if this the phenomenon you're experiencing but could help:
" 9. A reaction disc is a small rubber disc which lives under the head of the booster output push rod. If this is lost, the brakes will be nearly uncontrollable with stopping proportional to pedal position, not pedal effort, sending you through the windscreen at the lightest touch."
I have experienced this one. quote taken from hoppers stoppers website , handy hints page.
As MJH said, is very possible it has something to do with the bore relationship of the m/cyl to the caliper pistons though.
jesseT18
Castle Hill, Sydney
Re: incredibly soft brake pedal Sat, 07 May 2005 01:00 Go to previous messageGo to next message
yeah its definately not just me, the pedal is way to soft.
it could very easily be a part missing from booster/master, i guess ill pull em down and have a closer look
Turbo_Tim
Townsville
February 2005
Re: incredibly soft brake pedal Sat, 07 May 2005 01:09 Go to previous messageGo to next message
I find our t18 is the same, really easy to lock the fronts with barely any pressure. I think the camber and crappy tires have something to do with that.
My guess is that you had some vacuum issues previously that you have fixed.
TheStitt
Membership Secretary
Re: incredibly soft brake pedal Thu, 12 May 2005 06:14 Go to previous messageGo to next message
I drove this car last night at the drags.
U push the pedal and nothing happens untill say the last 30% or so of travel.
In this last % of travel the pedal is very firm and the car does pull up. Mind you this was only in the staging lanes car was pulled up from 30kph or less.
Got me stumped as to what is wrong
HyDrA
Adelaide, SA
Re: incredibly soft brake pedal Thu, 12 May 2005 08:09 Go to previous messageGo to next message
Maybe something to do with the corona master cylinder?? The pushrod needs to actually make contact with the master cylinder piston before anything happens - could this be part of it?
EVOSTi
cambo
      no
Re: incredibly soft brake pedal Thu, 12 May 2005 10:00 Go to previous messageGo to next message
thats sounds VERY reasonable. sometimes when people change m/c they dont measure the PISTON ROD DEPTH. it must be the same as the orignal m/c otherwise the rod out of the booster needs to be adjusted (some are adjustable) or modified.
what did the car run?
jesseT18
Castle Hill, Sydney
Re: incredibly soft brake pedal Thu, 12 May 2005 10:06 Go to previous messageGo to next message
the hole brake setup worked fine in the car i took it out of, nice stiff pedal
when i put it into my car it worked well, nice feel to it
only since ive had it all out and put back in has it been soft.
im thinking i might have left a part out from booster/master?
my best time was a 15.8
oh and luke- i tried pumping it today, they dont change at all, pedal stays soft
[Updated on: Thu, 12 May 2005 10:07]
EVOSTi
cambo
      no
Re: incredibly soft brake pedal Thu, 12 May 2005 10:20 Go to previous messageGo to next message
yeah but maybe the car you took it out of had the rod adjusted diferently, unless you used the booster from that car too? either way, take the m/c off and measure the depth of the piston to base, and measure how far the rod sticks out past the mounting point on the booster, they should be the same.
Secoh
Re: incredibly soft brake pedal Thu, 12 May 2005 18:39 Go to previous messageGo to next message
I bet you have swapped the brake calipers from left to right by accident Razz it'll never bleed properly because the bleed screw is in the wrong position to let the air escape. Has this been checked?
M.J.H
Re: incredibly soft brake pedal Fri, 13 May 2005 05:20 Go to previous messageGo to next message
maybe you need to go back to the start.
get some clamps to block off each flexible hose and see how the pedal feels then.if it's still crap then you have air or other prob at the master cyl.(i'm assuming you bleed the master cyl first.)
If the pedal is nice and hard then get someone to remove the clamps one at a time and when it goes from a good feel to crap then you will find which wheel the prob will be at.
Sounds like there might be air in the system still so do this to find out where.
jesseT18
Castle Hill, Sydney
Re: incredibly soft brake pedal Sat, 14 May 2005 08:26 Go to previous messageGo to next message
Quote:
I bet you have swapped the brake calipers from left to right by accident it'll never bleed properly because the bleed screw is in the wrong position to let the air escape. Has this been checked?
thats possible! ill check it out tomorrow
Secoh
Re: incredibly soft brake pedal Tue, 17 May 2005 14:49 Go to previous messageGo to next message
How did you go with this? The lack of response means either you haven't found it yet, or it was something so obvious you don't want to tell anyone! Laughing Razz
jesseT18
Castle Hill, Sydney
Re: incredibly soft brake pedal Wed, 18 May 2005 07:47 Go to previous message
OR
ive been flat out and havent had a chance to check it yet!
im finding a hell of a lot less time for my car now since i got my licence back
Previous Topic:18rc w/ 88230 head, timing chain kit?
Next Topic:Doing up an echo
Current Time: Wed Oct 28 14:01:47 UTC 2026
Total time taken to generate the page: 0.11529088020325 seconds
