Classifieds » Parts Wanted » Metal HEADGASKET for 7MGTE Urgently!
Mr.TRIM
Metal HEADGASKET for 7MGTE Urgently! Thu, 05 May 2005 14:26 Go to next message
As I sad, need metal or copper headgasket for 7mgte supra engine (new gaskets only),
jackel
Re: Metal HEADGASKET for 7MGTE Urgently! Thu, 05 May 2005 16:14 Go to previous messageGo to next message
how many mm, my friend has a brand new stock one i think
hamgatan
Re: Metal HEADGASKET for 7MGTE Urgently! Fri, 06 May 2005 00:59 Go to previous messageGo to next message
pm bbbachyyy... hes got a 1.3mm Cometic MHG for $175 + $15 to ship..
bbaacchhyy
Re: Metal HEADGASKET for 7MGTE Urgently! Fri, 06 May 2005 03:18 Go to previous messageGo to next message
hamgatan wrote on Fri, 06 May 2005 10:29
Correcto mundo.
Don't you want it anymore Hamgatan ?
Michael B
hamgatan
Re: Metal HEADGASKET for 7MGTE Urgently! Fri, 06 May 2005 03:30 Go to previous messageGo to next message
not sure hey Mike, reason is im thinking of going 2mm.. im going to use 0.20 over pistons on it.. would have though 2mm to be a better choice..yes?
bbaacchhyy
Re: Metal HEADGASKET for 7MGTE Urgently! Fri, 06 May 2005 05:38 Go to previous messageGo to next message
hamgatan wrote on Fri, 06 May 2005 13:00
Depends on what you want to do with the car - eg boost being planned, I/C used, computer being used, whether the block has been decked/head shaved etc.
Just going up in overbore (piston size) doesn't mean you need to increase the head gasket thickness.
It should be based on static compression ratio and the above factors that I mentioned.
Now, back to the thread. I have one avaiolable. Ring me on 042 111 9249 if anyone is interested
MB
hamgatan
Re: Metal HEADGASKET for 7MGTE Urgently! Fri, 06 May 2005 08:06 Go to previous messageGo to next message
yeah it will be decked and shaved.. most likely going to use PFC F-CON/VPC/FCD tied in with my S-AFC and an AVC-R.. boost around 20psi or so later on bigger turbo..
Mr.TRIM
Re: Metal HEADGASKET for 7MGTE Urgently! Sat, 07 May 2005 06:20 Go to previous messageGo to next message
Hi bbaacchhyy, tried to ring ya but no luck.
Call me on 0402001471 if y got time,
Mr.TRIM
Re: Metal HEADGASKET for 7MGTE Urgently! Sat, 07 May 2005 06:21 Go to previous message
jackel wrote on Fri, 06 May 2005 02:14
Thanks man, but i`m not after stock one. This time i need metal hg
Let me know if ya got one.
TTY
Previous Topic:3S-GE Engine
Next Topic:T50 or bellhousing to suit 4AGE rwd
Current Time: Thu Oct 29 12:58:32 UTC 2026
Total time taken to generate the page: 0.0063109397888184 seconds
