Toymods » Tech & Conversions » Hand Brake Cable for Hilux in Ra23 Conversion
stradlater
Arthurs Creek, Victoria
Hand Brake Cable for Hilux in Ra23 Conversion Fri, 06 May 2005 05:12 Go to next message
What did people do for a hand brake cable in the hilux/ra23 conversion?
Re: Hand Brake Cable for Hilux in Ra23 Conversion Fri, 06 May 2005 05:19 Go to previous messageGo to next message
When I fitted the hilux diff to my TA22 I found that the factory TA22 cable was perfect once I spread the fingers a bit. Have a look at that.
stradlater
Re: Hand Brake Cable for Hilux in Ra23 Conversion Fri, 06 May 2005 05:20 Go to previous messageGo to next message
Spread which fingers we talking about?
Re: Hand Brake Cable for Hilux in Ra23 Conversion Fri, 06 May 2005 05:24 Go to previous messageGo to next message
On the end of the hand brake cable there is the bit with the fingers that holds the cable into the backing plate. Its these fingers that needed to be spread a tad.
stradlater
Re: Hand Brake Cable for Hilux in Ra23 Conversion Fri, 06 May 2005 05:26 Go to previous messageGo to next message
I see that you've got ma70 discs though, would this idea still apply to the std hilux brakes?
Re: Hand Brake Cable for Hilux in Ra23 Conversion Fri, 06 May 2005 05:28 Go to previous messageGo to next message
Yeah I tried it on the early Hilux backing plate it also worked. But you'll have to double check with what you have. I'm not even sure if the RA23 cable is the same as the TA22 Confused
stradlater
Re: Hand Brake Cable for Hilux in Ra23 Conversion Fri, 06 May 2005 05:29 Go to previous messageGo to next message
This is a very valid point, but there's a fair chance it is.
ra_28
Re: Hand Brake Cable for Hilux in Ra23 Conversion Fri, 06 May 2005 07:16 Go to previous messageGo to next message
I used hilux cables right up to the hand brake then used the original short piece with the tread on it very easy. up near the short end i have a half moon piece which the hilux cables runs through and the original short cable hooks into.
stradlater
Re: Hand Brake Cable for Hilux in Ra23 Conversion Fri, 06 May 2005 07:23 Go to previous messageGo to next message
so the hilux cables were short enough were they?
Re: Hand Brake Cable for Hilux in Ra23 Conversion Fri, 06 May 2005 08:18 Go to previous messageGo to next message
I just shortened the Hilux cables, works fine.
stradlater
Re: Hand Brake Cable for Hilux in Ra23 Conversion Fri, 06 May 2005 08:57 Go to previous messageGo to next message
But don't they have crimped fittings on the end that you can't re-crimp?
Fattony
Re: Hand Brake Cable for Hilux in Ra23 Conversion Fri, 06 May 2005 18:49 Go to previous message
You can crimp the fittings or have the bronzed on
Previous Topic:r154 speedo driver question/ 1jz ecu questions
Next Topic:Exhaust Manifold
Current Time: Thu Nov 19 12:45:48 UTC 2026
Total time taken to generate the page: 0.0053749084472656 seconds
