Toymods » Tech & Conversions » when should my engine stop reving??
lilcrash
ipswich queensland
when should my engine stop reving?? Fri, 06 May 2005 05:16 Go to next message
i was playing with my enigne and ecu this morning and thought i might try running the factory settings that came in my ecu to see if it runs any better or worse as my car is chewing fuel.
so i started righting down the settings i had in my ecu so if it turned out bad i could ptu it all bak.
i remapped the ecu first bar was .13 last bar was 4.10 with a nice gentle angle. it wouldnt run, i started remapping backwards down the scale and after i had put the last 3 bars to 10.30,10.30 and 10.11(at this point the rest of the map was still between .13 and 3.Cool i got it to start but it would only run with my foot close to the floor and really lumpily(like a bridgeport rotor sounds) and i was watching the enigne data screen on my lap top and it was revving between 6k-12k.
now my question is - is it possible that my enginge did rev that fast or was the computer getting bad sigals??
thanx
berad
Re: when should my engine stop reving?? Fri, 06 May 2005 05:19 Go to previous messageGo to next message
i think ur gettin abd signals... wat engine is it though
ke382TG
Re: when should my engine stop reving?? Fri, 06 May 2005 05:22 Go to previous messageGo to next message
You would have certainly known if it went to 12,000rpm Shocked
1. Repeat what you did
2. Film it and post it for us to watch Laughing
Corona RT142
Campbelltown
solution hold it at what the computer says is 12K if it blows up it is right, otherwise the signal is fubered
setsuna
Re: when should my engine stop reving?? Fri, 06 May 2005 05:40 Go to previous messageGo to next message
someones going to pop his engine screwing with these settings!
if it runs lean.. then pingaling!
and.. stuff..
got any mates who know what they are doing? Razz
gearb0x
Re: when should my engine stop reving?? Fri, 06 May 2005 06:54 Go to previous messageGo to next message
setsuna wrote on Fri, 06 May 2005 15:40
and.. stuff..
i second that, blindly playing with ur ECU settings isnt going to lead to much good, atleast use a narrowband 02 sensor with a crappy guage to make sure its not leaning out bad
ke382TG
Re: when should my engine stop reving?? Fri, 06 May 2005 06:57 Go to previous messageGo to next message
and.. stuff.
Pff sif any problems could happen, engines are tuff, made from steel and alloy and nuts and bolts. Keep playing, you will probably learn a valuable lesson Evil or Very Mad
lilcrash
ipswich queensland
Re: when should my engine stop reving?? Fri, 06 May 2005 07:51 Go to previous messageGo to next message
enigne is a 2tgeu.
i think i might stop playing with it, but i am going to buy a tacho so i can see wat my enigne is revving to neway.
if i could find sumone capable to tuneing it i would happily pay to get it done. but no one i have found can do it except redcliffe dyno and it will cost me more in fuel to get there then wat it will cost to get it tuned.
does neone know of sumone in or near ipswich that can tune haltechs (my ecu is a f7b, so u need win98 and a serial port)
laterdays
barned01
Re: when should my engine stop reving?? Fri, 06 May 2005 09:16 Go to previous messageGo to next message
first of all i don't condone what i am about to offer and take no responsibility but:
i am using a haltech f7c on an 18rgeu
compression is 150psi in the cylinders +/- 3psi
redline according to the tacho in the car is about 6000 rpm (but it does go higher.)
now knowing that a 2t and an 18r have rather large differences in compression chamber volumes, i am still nevertheless happy for you to borrow mine if you feel like it, that you can play with.
it shouldn't blow your engine i wouldn't think as it would require more fuel to spark the g engine rather than the t engine, so if you tried it on yours it would probably run rich still.
but if you still want to try it let me know.
muaythaiman
Re: when should my engine stop reving?? Fri, 06 May 2005 09:42 Go to previous messageGo to next message
12,000rpm? pffft. Go for 15.
fester
Gympie Qld
Re: when should my engine stop reving?? Fri, 06 May 2005 12:14 Go to previous messageGo to next message
One would assume any of the following authorised dealers should be able to tune it for you, have to rung around.
Australian Dealerships
Dealer: Acacia Ridge Auto Electronics Dealer: Advanced Performance Centre
Dealer: All Star Tuning
Location: 27-10 Militiadis St, Acacia Ridge 4110 Location: 2928 Logan Rd, Underwood 4119
Contact: Contact: Nick Zervos
Contact:
Phone: (07) 3277 8340 Phone: (07) 3341 7223
Phone: (07) 3265 7185
Fax: Fax: (07) 3341 2488
Fax:
email: email: email email:
Dealer: Automotive Technique Dealer: Bob Romano Performance Motors
Dealer: Boost Motorsports
Location: 4a 1/4 Kendor St, Labrador 4215 Location: 387 Lytton Rd, Morningside 4170
Contact: Contact: Bob Romano
Contact: Joe Kingston
Phone: (07) 5537 1515 Phone: (07) 3395 8255
Phone: (07) 4951 0022
Fax: (07) 5529 0479 Fax: (07) 3395 8266
Fax: (07) 4951 0033
email: email email: email email: email
Dealer: Buzz Engines.com Dealer: HiFlo Dealer: Mike Vine Turbo's
Location: 2/21 Jijaws St, Sumner Park 4074 Location: 155 McDougall St, Toowoomba 4350 Location: 475 Redland Bay Rd, Capalaba 4157
Contact: Adam Burgess Contact: Contact:
Phone: (07) 3279 4989 Phone: (02) 4659 0102 Phone: (07) 3206 4799
Fax: (07) 3279 4999 Fax: Fax:
Dealer: Millenium Motorsports Dealer: Q-Mechanical
Dealer: Redcliffe Dyno and Performance
Location: 2/27 Millennium Pl, Tingalipa 4173 Location: Gate 2 , 371 Tailor St
Toowoomba 4350 Location: 8 Cameron St, Clontarf 4019
Contact: Contact: Rob Contact: Steven Leerendveld
Phone: (07) 3348 2755 Phone: (07) 4633 6642 Phone: (07) 3284 1925
Fax: Fax: (07) 4633 6601 Fax: (07) 3883 1355
email: email: email email: email
takai
Re: when should my engine stop reving?? Fri, 06 May 2005 12:16 Go to previous messageGo to next message
Heh, formatting got screwed there. Try www.haltech.com.au for a list of dealers.
Alchemist
Re: when should my engine stop reving?? Sat, 07 May 2005 03:57 Go to previous messageGo to next message
A 2T-GEU @ 12,000RPM? Rolling Eyes I reckon you could get to 8 or 9 maybe...More realistically I think you were probably doing 6500-7500 that's about it for a 2T.
[Updated on: Sat, 07 May 2005 03:58]
Corona RT142
Campbelltown
Re: when should my engine stop reving?? Sat, 07 May 2005 04:09 Go to previous messageGo to next message
the engine in one of the current jags was tested to 13000rpm and it ran there constantly for a couple of hours with no issue, read it a while back in motor, was in prelimanary testing for an upcoming model, i don't know whether i believe it or not but thats pretty good if it did, but yeah i'd say your computer is wack.
[Updated on: Sat, 07 May 2005 04:10]
Alchemist
Re: when should my engine stop reving?? Sat, 07 May 2005 04:14 Go to previous messageGo to next message
Corona RT142 wrote on Sat, 07 May 2005 14:09
the engine in one of the current jags was tested to 1300rpm and it ran there constantly for a couple of hours with no issue,
Mate that's a cold idle! Laughing
[Updated on: Sat, 07 May 2005 04:14]
Corona RT142
Campbelltown
Re: when should my engine stop reving?? Sat, 07 May 2005 04:22 Go to previous messageGo to next message
Alchemist wrote on Sat, 07 May 2005 14:14
fucking typo, i had already edited before you posetd so how did that happen read 13000rpm not 1300rpm
Alchemist
Re: when should my engine stop reving?? Sat, 07 May 2005 04:24 Go to previous message
Sorry mate, couldn't resist, The email I got from the toymods automatic thingy said 1300, after I'd posted it then said 13,000.
Previous Topic:Getting a Microtech 2ndhand
Next Topic:2JZGTE in a MX13 rona....
Current Time: Thu Nov 19 08:21:42 UTC 2026
Total time taken to generate the page: 0.0065860748291016 seconds
