Toymods » Tech & Conversions » 3t-gte oils
steve-O
wollongong
3t-gte oils Fri, 06 May 2005 12:16 Go to next message
hey guys i'm gonna be putting my 3t-gte back together over the next couple of days and i'm gonna run it in. just wanted to know what oil people use in their 3t-gte's. brand, viscosity etc. and how you rate it
ta23
Re: 3t-gte oils Sat, 07 May 2005 00:49 Go to previous messageGo to next message
I use penrite HPR30 in mine, seems to be fine, but I would also be interested in what other oils would be reccomended for this engine.
What are peoples opinions in using synthetic oil in this engine, I was told not to worry as the 3TGTE is an older motor and synthetics wouldnt have been around when the 3TGTE was developed.
Could I consider using sythetics with an upgraded turbo / intercooler on the 3TGTE or should I just stick to what I am using.
rb20det
Re: 3t-gte oils Sat, 07 May 2005 01:19 Go to previous messageGo to next message
i use pennzoil gt perfomance synthetic 10-40. i was told only to use a synthetic on a motor if it had been completly rebuilt. and not to use a 5 wieght oil on old design engines as it results in low oil pressure.
filthman
Heathmont, Melbourne, Vic
Re: 3t-gte oils Sat, 07 May 2005 01:27 Go to previous messageGo to next message
Synthetic oils are fine in older engines, but don't put it straight into your freshly rebuilt engine or they wont allow the components to bed in properly. Only put it in after the engine is run in.
On saying that though, plenty of engines have done plenty of miles on mineral based oil, just don't run your $6 Kmart blend in it Laughing , the heat from the turbo will break it down in no time
YelloRolla
On your mum!
Re: 3t-gte oils Sat, 07 May 2005 05:03 Go to previous messageGo to next message
I use penrite HPR15 (30 is fine too) or BP corse plus.
30w monograde for the run-in process.
Toobs
Re: 3t-gte oils Sat, 07 May 2005 12:51 Go to previous messageGo to next message
The 3T won't have a problem if you chuck in 5W/50 or 5W/60 in it.
Its only if you chuck 5W/30 or lower that you'll have problems with oil pressure.
The 3T I had used to run 15W/50 Semi Synth all the time.
PS your k-mart $6 blend will just be a rebranded entry level mineral oils from one of the big oil companies (e.g. Castrol, Ampol, Shell etc.)
Just don't buy anything that says "recycled" or similar.
steve-O
wollongong
Re: 3t-gte oils Mon, 09 May 2005 07:10 Go to previous message
cool well now i have a list of oils i can use. thanks guys.
Laughing i completely forgot about this thread
Previous Topic:Article - Putting S13 susp into AE86
Next Topic:3VZ-FE misfire
Current Time: Fri Nov 20 09:00:30 UTC 2026
Total time taken to generate the page: 0.012479066848755 seconds
