Toymods » Tech & Conversions » KE70 to TE70
roger
KE70 to TE70 Thu, 21 November 2002 00:09 Go to next message
Am I correct?
A T18 - TE72 cross member will bolt into a KE70?
what about the gearbox cross member?
roger
Purple_Beasty
New Zealand
Re: KE70 to TE70 Thu, 21 November 2002 00:25 Go to previous messageGo to next message
Steering is completely different, KE is rack and pinion while TE has a steering box. Have seen it swapped, but there is a fair bit of work required. Easier to cut mounts off TE crossmember and weld to KE crossmember. Gearbox mount will fit as there are extra holes there already for it to bolt to (from hazy memory).
roger
Re: KE70 to TE70 Thu, 21 November 2002 00:54 Go to previous messageGo to next message
Thanks Purple Beastie thats what I needed to know. Any one done this conversion and changed the rack and pinon onto the TE72 cross member? how hard was it? What was involved?
[Updated on: Thu, 21 November 2002 00:56]
Purple_Beasty
New Zealand
Re: KE70 to TE70 Thu, 21 November 2002 02:14 Go to previous message
Just to clarify, I meant change engine mounts not the rack mounts. If you can avoid it you really don't want to mess with steering as even a couple of degrees out can really screw your handling.
See http://www.tassie.net.au/~jar for info on the engine mounts.
Previous Topic:Attention: Lucan B.
Next Topic:supra 5 spd on 4A-GE speedo drive?
Current Time: Sun Nov 1 05:01:39 UTC 2026
Total time taken to generate the page: 0.0096838474273682 seconds
