Toymods » Tech & Conversions » Questions about 4age bigport 16v
Choony_AE86
Melbourne, South East
Questions about 4age bigport 16v Fri, 06 May 2005 14:03 Go to next message
Just need some information guys:
1. Are the valve lifters and shims in the head of this engine identical for exhaust and inlet sides?
2. I was looking at the picture in tech docs of toymods of cylinder head picture 1 of a pretty intense engine in a lotta bits with labellings and numbers. I noticed numbers such as '280 (20,27)' does this represent the torque settings? if so which part does? is it in kg.cm or ft.lb?
thats got me pretty confused.
3. I need the torque settings for a lot of the bits of the engine, if question 2 is correct and those numbers represent torque settings than ignore this question please.
I require NM for head, inc camshaft bearing cap, head to bottom end bolts, inlet mani, exhaust mani (im running extractors 4-2-1 is it differnt?), cam gears.
4. What are the Torque settings for flywheel? are they the same as the 20v? i ran a search and found 20v torque rate but not 16v.
Thanks in advance guys
Choony
PS: everything is stock, besides the extractors Smile
Choony_AE86
Re: Questions about 4age bigport 16v Sat, 07 May 2005 04:23 Go to previous messageGo to next message
please anyone feel free to help Very Happy
Big T
Re: Questions about 4age bigport 16v Sat, 07 May 2005 09:23 Go to previous message
Camshaft bearing caps: 12-14 Nm
Cylinder Head Bolts: 55-64 Nm
Camshaft Timing Pulley Bolt: 40-53 Nm
Timing belt idler pulley set bolt: 30-44 Nm
Spark Plugs: 15-20 Nm
Intake Mani: 26-30 Nm
Exhaust Mani: 22-27 Nm
Flywheel: 69-78 Nm
Seriously, invest in a 4age engine service manual. It is SOOOOOO useful. The manual is online so i don't know why you need to ask Rolling Eyes That only took me 2 mins to find all those settings in my book so it's definately an awesome investment.
In reference to the shims, you have to measure each one indivually. DONT mix up the order of them though because you need to know what shim gives what clearance and whether it's in tolerable ranges.
Eddie.
Previous Topic:SW20 Mr2 Power Output
Next Topic:Gz20 soarer 1g to 1jz conversion problems?
Current Time: Thu Nov 19 08:41:22 UTC 2026
Total time taken to generate the page: 0.0049929618835449 seconds
