Toymods » Tech & Conversions » 7mgte keep blowing HG, any help???
Mr.TRIM
7mgte keep blowing HG, any help??? Sat, 07 May 2005 06:32 Go to next message
hi b & g,
this is a third headgasket ( stock) retorqed properly to 78lbs that`s been blown running no more than 16psi.
Now this time i`m going for metal one, so i need to know which is the best one.
Questions:
1. how thick MHG i should get
2. what torque should apply
3. been told that mhg want fix problem as 7mgte are weak between 5-6 cyl(gap is too small) and it will keep blowing under high boost!
lobby69
Thornleigh sydney
January 2005
Re: 7mgte keep blowing HG, any help??? Sat, 07 May 2005 06:40 Go to previous messageGo to next message
to fit a MHG...
u need to have the head and block skimmed....the standard finish on the head and block is not smooth enought to completley seal a MHG,
until u do this...run less boost!
blake
allencr
tallahassee FL usOFa
Re: 7mgte keep blowing HG, any help??? Sat, 07 May 2005 15:42 Go to previous messageGo to next message
it's a super powerful, top of the class engine that has been running at its max, or it's an improper install - preparation and/or technique. how long between the 3 BHG's??
the surface of the block, head, bolt head & washer, and the condition of the threads on the block and bolts.
what does this mean - step by step????
ed_ma61
Lost in the K hole
Re: 7mgte keep blowing HG, any help??? Sat, 07 May 2005 17:03 Go to previous messageGo to next message
a) theres nothing special about the #5 -#6 cyl wall gap... that excuse is pretty lame. bore spacing is equal, and though minimal, should be adequate for 99% of build ups
b) a MHG will fix the problem if:
- the head and block are surfaced PROPERLY
- theres not too much corrosion in the block/head water galleries
- you use Hylomar on the MHG
c) NEW stock head bolts should be torqued to 72ft/lbs only, with proper lube, not oil, not dry, in recently threaded block threads
d) if going ARP fasteners, follow thier guidlines, dont guess
e) thickness should be exactly the same as the HG coming out (1.2mm ??)
chrisss
melb
Re: 7mgte keep blowing HG, any help??? Sun, 08 May 2005 11:13 Go to previous messageGo to next message
ed u said 72 ftlbs torque.....vs 78 ftlbs - thats not a huge difference, I doubt half the torque wrenches out there would still be reading that accurately.
is the 7m that sensitive to correct torque?
ed_ma61
Lost in the K hole
Re: 7mgte keep blowing HG, any help??? Sun, 08 May 2005 16:09 Go to previous messageGo to next message
chrisss wrote on Sun, 08 May 2005 21:13
no, but the bolts might be Rolling Eyes
Mr.TRIM
Re: 7mgte keep blowing HG, any help??? Mon, 09 May 2005 07:43 Go to previous messageGo to next message
Thanx guys for advice.
By the way i have standard studs and head has been shaved.
Not sure about block, cos i`ve bought this engine not long ago.
Engine by itself had 85000kms and will check block for detorations.
any other advice ( a heard some people apply between 90-100 Nm)???
How much is this in lbs?
Any other advices?
Allan
Re: 7mgte keep blowing HG, any help??? Mon, 09 May 2005 10:04 Go to previous messageGo to next message
Mr.TRIM wrote on Mon, 09 May 2005 17:43
Standard studs you meen bolts?
TerryOBeirne
Redbank Plains,near Ipswi...
Re: 7mgte keep blowing HG, any help??? Mon, 09 May 2005 12:05 Go to previous messageGo to next message
you may have a soft head. this is common on overheated engines. any engine shop can test it. surface finish is critical as several people have said. your chance of getting a good enough block finish when its sitting in the engine bay, is very small, bordering on stuff-all. I have never seen any metal gasket maker recommend a spray like hylomar. the gaskets have a teflon coating from factory. the 7m does not have studs, it has bolts. toss them away and use new ones torqued to correct value, nothing more.
YelloRolla
On your mum!
Re: 7mgte keep blowing HG, any help??? Mon, 09 May 2005 12:19 Go to previous message
66.4 to 73.8 ft/lbs.
try typing "conversion table" into google and you will come up with many sites that can convert just about anything that you can think of.
Previous Topic:Aftermarket Cams for 3sge!!! After mild setup
Next Topic:wanna polish up my dragways
Current Time: Sun Oct 18 23:00:53 UTC 2026
Total time taken to generate the page: 0.0063648223876953 seconds
