Toymods » Tech & Conversions » Sprinter will not go into reverse....
Taqe
March 2005
Sprinter will not go into reverse.... Sat, 07 May 2005 16:03 Go to next message
Hi guys and gals. Was driving my Sprinter and everything was cool, parked the thing and couldnt get into reverse. Can anyone tell me y something like this would happen. Had to push ma car into driveway. any help would be greatly appreciated.
EldarO
Perth, WA
Re: Sprinter will not go into reverse.... Sat, 07 May 2005 16:26 Go to previous messageGo to next message
mines a whore to get into reverse sometimes, i dunno why, usually letting the clutch out in neutral and pushing it back in solves the problem but..
i could ram it into gear if i liked it rough...
sorry im not helping at all Confused
Eldar.O.
driftae86
perth
Re: Sprinter will not go into reverse.... Sat, 07 May 2005 16:31 Go to previous messageGo to next message
i always go into first then into reverse, tends to stop it from crunching and if it doesnt go into reverse, clutch out, clutch in then try again. tends to more of a habit now.
does it still not go into reverse? have you tried again since the incident?
and if that doesnt solve it...maybe your gb is stuffed? but im no expert.
Arch
Re: Sprinter will not go into reverse.... Sun, 08 May 2005 00:02 Go to previous messageGo to next message
I go into third and then into reverse, this makes it slot into reverse with almost no effort. Going from first into reverse works aswell, but doesnt feel as nice.
re-clutching sometimes is needed too. I hate when it crunches, not only do u get that weird feeling all the way through your spine, its fukn embarrising!
Taqe
March 2005
Re: Sprinter will not go into reverse.... Sun, 08 May 2005 00:31 Go to previous messageGo to next message
Have tried putting in first then reverse but still no response. When i pull the gear stick all the way to the right i just cannot move it down at all. I think my gearbox is bunnnged up.
toof
Re: Sprinter will not go into reverse.... Sun, 08 May 2005 00:43 Go to previous messageGo to next message
my box in the mr2 can be fairly stiff at times. i put it into second then reverse if that dosent slide in eaisly then neutral -> clutch out -> second -> reverse. or if its just stuck on the gate and not sliding in nicely just let the clutch out the tinyest bit just its *just* engaging, just enough to move the gears a tiny bit if usually enough to let reverse go in eaisly.
Re: Sprinter will not go into reverse.... Sun, 08 May 2005 02:17 Go to previous messageGo to next message
Try putting it in another gear, as suggested, and if that doesn't work too well, try turning the engine off. If it goes in easy then, something's up with your clutch system, and is fairly to fix.
Callifo
Gawler, SA
Re: Sprinter will not go into reverse.... Sun, 08 May 2005 02:56 Go to previous messageGo to next message
Happens very rarely but I find its easiest to let the car move even a little bit lets it pop in perfectly. Either roll or just pop in first and accelerate so the car moves even a cm.
Could it be because the gear teeth arent lined up properly when your trying to push it in? (not familiar so its just a guess)
toyoman-saw
Whyalla
May 2005
Re: Sprinter will not go into reverse.... Sun, 08 May 2005 04:10 Go to previous messageGo to next message
i usually wack it on 3rd then reverse.. its always a good idea to wach it in any gear not straight into reverse or it will crunch..
Celica_John
Re: Sprinter will not go into reverse.... Sun, 08 May 2005 07:33 Go to previous messageGo to next message
When my brother got a new box put in in his n14 pulsar it was fine for a few weeks but then all of a sudden WHATEVER you did it didn't go into reverse.
about a week later it just magically fixed itself.
DRFT - 86
Batemans Bay, NSW
February 2005
Re: Sprinter will not go into reverse.... Sun, 08 May 2005 11:58 Go to previous messageGo to next message
yep, my sprinter box is just like all mentioned above.... reverse is a bitch sometimes..
RobertoX
Re: Sprinter will not go into reverse.... Sun, 08 May 2005 23:57 Go to previous message
Hmmm... Sounds like a problem with the gate that stops it going into reverse from 5th.
I found that if the gate wont let you in then put it into 4th and then into reverse. I always would put it into another gear before reverse also Smile
Previous Topic:Coilover Sleeve KITS
Next Topic:need measurements for 7M ARP main studs
Current Time: Fri Nov 20 04:27:24 UTC 2026
Total time taken to generate the page: 0.0066118240356445 seconds
