Classifieds » Car/Engine Electronics & Audio » FS: G-tech, in-car tv/dvd setup, 1991 sx promo vid
cam_RA40
Launceston, Tasmania
haha, funny little head!
FS: G-tech, in-car tv/dvd setup, 1991 sx promo vid Sun, 08 May 2005 04:08
got a few things for sale at the moment, buyer pays postage which shouldn't be much:
G Tech PRO Performance Meter $60
Comes with original box, manual, g-tech sticker & everything else
Only had this for 3 or 4 days, i did a few runs in my car and am over it Razz works perfect
http://img108.exs.cx/img108/7284/gtech21ub.jpg
Car DVD/TV setup, includes the following items:
Motorized 7" Widescreen Monitor with TV Tuner, AM/FM Radio & Amp
http://brashimports.com.au/8988black111.jpg
Features
In-dash 7-inch TFT color monitor
Fully motorized
Built-in PAL TV tuner for Australian Channels
Built-in AM/FM stereo receiver
Built-in 4-channel amplifier (4 x 50W)
One A/V input for PS2, Xbox, GPS, Camera etc
RCA level A/V output
CD/VCD/DVD changer control
Front panel LCD
Auto channel setup
Memory preset AM/FM stations
Fully on-screen menu display
Volume, treble, bass balance fader controls
Brightness, contrast, color controls
Last position memory
Real time display
Full-function infrared remote control
Single DIN size
Wire harness on plug
Amplifier and auto antenna wires
DVD player with FM Modulator/Transmitter
http://brashimports.com.au/dv-17%20Black%20Large.jpg
Features
DVD/VCD/SVCD/CD/HDCD/MP3/WMA/JPEG/Kodak Picture CD/CD-R/CD-RW/DVD+RW/DVD-RW Compatible
Multi-Function IR Remote Controller
Video and Audio Outputs /Inputs Jack
Video Output
Full Function Infrared Remote Controller
16:9 or 4:3 Aspect Ratio
540 Line High Resolution Output
Multi-Language Menu & Subtitles
Multi-Angle Viewing Function
Standard Din Size and will fit most cars
Product dimension: 16x16x5cm.
Net weight: 1.1Kg
DC 12V (9-15 V) Supply
DC12V Output Jack
***This turned out to be a tiny bit thinner than the standard Din size meaning that i needed to use about 3 washers on each side before the mounting bracket. Still fits in a din hole fine & easily though. Also, this unit requires an optional remote sensor for the remote to work (plugs in the back) i know of a wholesaler in victoria who has these very cheap if you want one, he will post out to anywhere in aus. I didn't worry about it because you can do everything with the buttons on the face. Remote is still included minus the optional sensor.
Antenna with booster
http://brashimports.com.au/Single%20Diversity%20Large.jpg
Features
Reception Channels: FM(60mhz-100mhz)
VHF (1CH-12CH)
Supply voltage: DC12V (10.8-15.8V) (negative earth)
Power supply fuse (1.5A)
Booster gain
5-9db(VHF Band), 4-8 db (UHF Band)
Connection outlet antenna plug: diam. 1 or 2 x 3.5mm (standard Headphone size) (75ohm) please specify
Length of the cord: 4.8 M
Weight: indoor antenna, subtle: approx.400g
Power Boosted Film On Glass Antenna
http://brashimports.com.au/antenna%20-%20film%20-%20large.jpg
Features
Theft Proof Design
Connection outlet, antenna plug: diam. 3.5mm(75ohm)
***hasn't been stuck down before so is still good to be put on a window, i ended up just laying it down in my roof lining.
I purchased this package less than a month ago and have had it running without a problem in my ae92 since. The reason for selling is that i am selling my car soon and the purchaser doesn't want the tv/dvd setup. Asking price for the 4 above items is $550, the unit supports dual antenas so they can both be used at the same time for better TV reception.
Original 1991 Corolla SX Promo video(not sure if this was the right category or not)
This is the same as the one uploaded on Rollamods webpage although mine is an original with proper toyota cover and doesn't have the totally wild bit at the start Razz
make an offer!
Previous Topic:FS: ST165 3SGTE
Next Topic:ae86 jdm digital dash for sale
Current Time: Sat Nov 21 05:38:54 UTC 2026
Total time taken to generate the page: 0.0042710304260254 seconds
