Toymods » Tech & Conversions » Sirvertop 20V brakes rim size
tanman
Sirvertop 20V brakes rim size Sun, 08 May 2005 07:55 Go to next message
Do stock 14 inch a392 corolla alloys fit over AE101 20V brakes?
tobyoste
Re: Sirvertop 20V brakes rim size Sun, 08 May 2005 22:18 Go to previous messageGo to next message
When I bought my silvertop for my AE93 it came with the larger brakes as part of the package. After removing the calipers, carefully masking taping them up and then painting them (and the other brake parts), I found upon fitting them that apart from the disc, the splash shield and the main bracket that the caliper bolts to, everything else (ie. caliper and pads, etc) were the same. The one thing that was not a simple bolt up was that the discs had a slightly different location bore diameter. I ended up boring them out a couple of mm and then press fitting in a bush so they had the correct diameter to locate them on the spigot on the hub.
Apart from that, they did bolt up fine with the standard rims with plenty of clearance.
Toby
jasonp1977
Re: Sirvertop 20V brakes rim size Mon, 09 May 2005 00:39 Go to previous messageGo to next message
if you get the twin-piston 20V brakes you will usually require 15" rims as a minimum unless you get a 14 with a lot of brake clearance.
FASTFOO
melb
February 2005
Re: Sirvertop 20V brakes rim size Mon, 09 May 2005 13:00 Go to previous message
I have two AE101 gt 20 valve corollas atm and 14" wheels are fitted standard
So YES!
MATT.
Previous Topic:How to fit RX7 calipers to an AE86 - Links to pics
Next Topic:4AGE extractors O2 sensor wont fit???
Current Time: Sun Oct 18 06:57:59 UTC 2026
Total time taken to generate the page: 0.023251056671143 seconds
