Toymods » Tech & Conversions » fly cutting 3tc forged pistons to suit 3tgte head
ta22celica_boy
fly cutting 3tc forged pistons to suit 3tgte head Sun, 08 May 2005 09:51 Go to next message
yeah just wondering if its possible to fly cut 3tc forged pistons to suit the 3tgte and if so how much does it cost? any info would be great.
cheers josh v
[Updated on: Mon, 09 May 2005 06:16]
goonman86
deloraine tas
Re: fly cutting 3tc to suit 3tgte head Sun, 08 May 2005 12:14 Go to previous messageGo to next message
a 3tgte is a turbo motor why would you want to use na pistons? maybe if you deck the hight of the pistons then i dont see why you cant use them. does any one elce have any idea????
ta22celica_boy
Re: fly cutting 3tc to suit 3tgte head Sun, 08 May 2005 18:09 Go to previous messageGo to next message
there turbo pistons they've got a comp. ratio of 8.8
pheonix83
Devonport Tasmania
Re: fly cutting 3tc to suit 3tgte head Sun, 08 May 2005 23:01 Go to previous messageGo to next message
factory cast pistons blow more often than a hooker in thailand, so i reakon the 3tc flycuts would too.
YelloRolla
On your mum!
Re: fly cutting 3tc to suit 3tgte head Mon, 09 May 2005 03:01 Go to previous messageGo to next message
factory 3T GTE has a comp ratio of 7.8:1
Running forgies to suit a 3TC is fine.
If you get the flat top 87mm 3TC forged pistons from Wiseco, they have sufficiently deep valve notchs.
You could mill (or turn) the comp dome down on a forged NA replacement piston in order to tailor the CR if it came to it.
One would be left asking why?
Lesson for today - flycutting is a milling process using a single point cutting tool. When decking cylinder heads and blocks for example "a flycutter" is used.
ta22celica_boy
Re: fly cutting 3tc to suit 3tgte head Mon, 09 May 2005 05:56 Go to previous messageGo to next message
they are aries 89mm forged pistons. i was just seeing if i had to do anything to the pistons as they are for single cam 3tc and not the twin cam 3tgte. so is there any differance, or can i use these forged 3tc pistons in the 3tgteu without any hassels?
YelloRolla
On your mum!
Re: fly cutting 3tc to suit 3tgte head Mon, 09 May 2005 06:23 Go to previous messageGo to next message
just check the piston to valve clearance by using some plasticine. Place a nice disc of plasticine on the piston top (about 3-4mm thick) dummy assemble the engine and trun it over. take the head off and check where the vavle has touched. Cut throught the plasticine in the thinnest area (using a plastic knife) and measure how much clearance that you have (3.0mm is a good safe clearance).
Having said all of that - finding blocks that will go out to 89mm is not all that easy.
ta22celica_boy
Re: fly cutting 3tc forged pistons to suit 3tgte head Mon, 09 May 2005 07:28 Go to previous messageGo to next message
cheers for that yellorolla, ill do that when i get the block back from bryant engineering.
TerryOBeirne
Redbank Plains,near Ipswi...
Re: fly cutting 3tc to suit 3tgte head Mon, 09 May 2005 12:13 Go to previous messageGo to next message
it depends on the psiton design. I tried this recently on a weisco set. the dome was too thin. I ended up buying a custom set.
YelloRolla
On your mum!
Re: fly cutting 3tc forged pistons to suit 3tgte head Mon, 09 May 2005 12:22 Go to previous message
terryobeirne - good point. According to something that I read piston crown thickness should be >6% of the bore dia.
Previous Topic:4AGE extractors O2 sensor wont fit???
Next Topic:Aftermarket Cams for 3sge!!! After mild setup
Current Time: Sat Oct 17 20:37:39 UTC 2026
Total time taken to generate the page: 0.0055921077728271 seconds
