Toymods » Tech & Conversions » How does a Crank angle sensor Work?
wiso
How does a Crank angle sensor Work? Sun, 08 May 2005 11:06 Go to next message
thats what I kinda need to know, I got one on a 4agze.
My problem is I have no spark from the coil packs, now these are working properly, I am pretty sure the igniter is working properly, but does the igniter gets its "ok" from the CAS after it goes into the ecu?
My questions are, How do you tell when you have the CAS at TDC?
And it has 4 wires out of it, what do these do? is it like one power, one ground, and 2 pick offs?
Re: How does a Crank angle sensor Work? Sun, 08 May 2005 12:26 Go to previous messageGo to next message
is probably covered somewhere in the tech articles on <www.autoshop101.com> ?
A quick google search of it suggests:
<http://www.autoshop101.com/forms/h40.pdf>
and
<http://www.autoshop101.com/forms/h25.pdf>
but if you have the time and bandwidth - download all the tech articles as they're quite a usefulread.
wiso
Re: How does a Crank angle sensor Work? Sun, 08 May 2005 22:20 Go to previous messageGo to next message
Ok thats good now I know how the system works, but I still need to know:
How do you tell when the CAS is at TDC?
From what I can tell in those articles it looks like my problem is those 4 lines. NE, G-, G1, G2
G- will run to a ground. but I can't tell is NE suppose to have power on it 12V or something.
10sec_rx7
Syndey
Re: How does a Crank angle sensor Work? Sun, 08 May 2005 22:55 Go to previous messageGo to next message
there is no 12v supply to magnetic sensors,
take it out and get someone to test it on a scope and that will tell you if it is working correctly
Dale
wiso
Re: How does a Crank angle sensor Work? Sun, 08 May 2005 22:57 Go to previous messageGo to next message
it should be working correctly, it was running on the previous owners car about a month ago
10sec_rx7
Syndey
Re: How does a Crank angle sensor Work? Mon, 09 May 2005 01:28 Go to previous messageGo to next message
so you have swapped engines and now it wont run??
it will be a wiring problem, you have 1 earth wire and 3 pickup wires inside, to get on TDC you must like up one of the pickups on the single tooth and put it in
wiso
Re: How does a Crank angle sensor Work? Mon, 09 May 2005 02:42 Go to previous message
I am 100% the wiring is correct to the CAS, so now I am thinking there is a problem in the igniter, cause this igniter wasn't off the same person I got everything else.
Thanks for your help guys
Previous Topic:$4000 walk-in walk-out SR20DET conversion for AE86?
Next Topic:Coilover Sleeve KITS
Current Time: Fri Nov 20 04:57:11 UTC 2026
Total time taken to generate the page: 0.032570123672485 seconds
