Toymods » Tech & Conversions » 3VZ-FE misfire
Datto-Zed
Townsville, NQ
May 2005
3VZ-FE misfire Sun, 08 May 2005 13:40 Go to next message
My fathers vienta has had a misfire problem for ages now, and no one has had any luck fixing the problem. Sometimes when something is changed it will temporarily cure the problem, but it always comes back. The misfireis totally intermittent and certainly not just one cylinder. Sometime it will be fine for a whole drive, others it will miss on and off the whole way. It's currently bad enough that it's almost undriveable. Spark plugs, leads, dizzy cap and rotor have all been changed.
It was at the local toyota dealer last week; they swapped the ecu between it and another vienta. Each ran fine with the others ecu, so they swapped them back, still ran fine. They test drove it for 30min, fine. I took it home, had to overtake, 80-130 foot to the floor, ran fine for the next few min, then has missed very badly since.
Any ideas? Anyone have a wiring diagram?
Where does the tacho get its signal from, the ECU or at the coil/igniter? That might be a bit of a clue seeing as the tacho does drop when it's missing.
Any help on this is greatly appreciated.
Re: 3VZ-FE misfire Mon, 09 May 2005 01:04 Go to previous messageGo to next message
Had the injectors cleaned?
Datto-Zed
Townsville, NQ
May 2005
Re: 3VZ-FE misfire Mon, 09 May 2005 06:10 Go to previous messageGo to next message
Nope....but the problem wouldn't be intermittent if it was dirty injectors.
Re: 3VZ-FE misfire Mon, 09 May 2005 06:12 Go to previous messageGo to next message
Probably not, but its worth a try since you have tried most other things.
Otherwise give it to an auto sparky place who look like they can work on Toyota's.
Datto-Zed
Townsville, NQ
May 2005
Re: 3VZ-FE misfire Mon, 09 May 2005 06:56 Go to previous message
Well....just got a call from toyota. Turns out the spark plugs in the rear bank of cylinders were fouled, due to a leaking head gasket. No surprise considering the front HG has gone previously.
Seeing as they'll charge an arm and a leg to change it, we'll just get them to throw in some new plugs which should tide us over for a while, then when time permits I'll do the head gasket myself.
Previous Topic:3t-gte oils
Next Topic:RA2x dash lights
Current Time: Fri Nov 20 08:45:49 UTC 2026
Total time taken to generate the page: 0.0076909065246582 seconds
