Toymods » Tech & Conversions » 7MGTE into Hilux 2WD 22R
1200det
7MGTE into Hilux 2WD 22R Mon, 09 May 2005 01:18 Go to next message
Has anyone done the 7MGTE conversion into the Hilux when removing the 22R ?
Just have a few questions in regards to Gearboxes to Use and engine mounts etc ??
-==L=a=N=c=E==-
Brisbane, Queensland
Re: 7MGTE into Hilux 2WD 22R Mon, 09 May 2005 01:25 Go to previous messageGo to next message
5ME engine mounts bolt onto the stock 22r mounts.
If you have a G52 gearbox it won't last against the torque, so look at replacing it with a W58 of somedegree (you do need the Wseries bell housing)
The rest consists of wiring and fuel.
1200det
Re: 7MGTE into Hilux 2WD 22R Mon, 09 May 2005 01:42 Go to previous messageGo to next message
Excellent thankyou
So if i pick some Cressida 5ME engine mounts that will get the engine mounted , what bellhousing would i need in the meantime to adapt the M series engine to the standard G series Lux gearbox ?
-==L=a=N=c=E==-
Re: 7MGTE into Hilux 2WD 22R Mon, 09 May 2005 03:28 Go to previous messageGo to next message
When i get home tonite ill forward you a link of a few guys that have done 7mg(t)e conversion. They run thru the process quite well.
The G series gearbox is the same as the W series gearbox except geared differently. So all you need is a 7mge bell housing. Easy huh.
i've researched this quite well, because i am going to do the same conversion on my dualcab ute once the old 22R shits itself.
1200det
Re: 7MGTE into Hilux 2WD 22R Mon, 09 May 2005 03:53 Go to previous messageGo to next message
If you could send that through this evening would be wonderful , I would also need to source the 7M flywheel and clutch , pressure plate etc
Know if the clutch fork etc is the same ?
-==L=a=N=c=E==- wrote on Mon, 09 May 2005 13:28
-==L=a=N=c=E==-
Re: 7MGTE into Hilux 2WD 22R Mon, 09 May 2005 05:45 Go to previous message
As promised here are a few links.
http://webpages.charter.net/dbcaudill/toyota_picku p_with_7mgte_supra_t.htm
http://www.webpages.uidaho.edu/~simm8647/4Runner/4 Runner.htm
http://www.supracharged.com/
http://www.off-road.com/toyota/tech/supraswap/inde x3.html
See what you can find out from them. They answered most of my questions except wiring.
Previous Topic:Air con for sprinter
Next Topic:Annoying high pitched whistle noise when on boost
Current Time: Fri Nov 20 07:11:08 UTC 2026
Total time taken to generate the page: 0.043226003646851 seconds
