Toymods » Tech & Conversions » Sparks coming out of exhaust...
greenta22
Dandenong Ranges, VIC
icon4.gif  Sparks coming out of exhaust... Mon, 09 May 2005 02:20 Go to next message
I was recently amusing myself on a skid pan, my mate was videoing me and he waved me to a stop and told me that he had seen sparks coming out of my exhaust. We figured that it must have been stones on the tyres or something and ignored it.
Last night I was doing roughly the same thing and I experienced some oil surge (OIL light came on repeatedly during hard cornering) when I stopped and got out of the car I noticed a fairly steady stream of red sparks being blown out of my tailpipe on idle. This lasted for 30 seconds or more. The coolant temp didn't go above 90. The motor is just a cammed up 2T with extractors etc.
What the hell have I done? The engine seems to perform normally still, which leads me to believe that it was just some carbon being blown loose at high revs (~7000rpm)
Anyone experienced something similar?
[Updated on: Mon, 09 May 2005 02:24]
Re: Sparks coming out of exhaust... Mon, 09 May 2005 02:28 Go to previous messageGo to next message
could be all manner of things:
bits of the CAT?
bits of the exhuast turbine?
bits of carbon deposits from back of zorst valves, interior of exhaust manifold and nearby piping being burnt off by your exhuberant driving?
bits of valve and pistons?
Re: Sparks coming out of exhaust... Mon, 09 May 2005 02:33 Go to previous messageGo to next message
Yeah, moneys on the cat.
Do you have one?
ke382TG
Sounds bad, did you park on top of a volcano?
I would also be concerned about your drops in oil pressure (the two problems may or may not be related). You may have some serious probs if you lose oil pressure, check the level is ok.
Bits of catalytic converter as chuck said is a likely cause. If you have no cat, you can forget this though.
greenta22
Re: Sparks coming out of exhaust... Mon, 09 May 2005 02:41 Go to previous messageGo to next message
Dont have a cat, its a carbied 2T. The oil pressure was only dropping for the duration of the corners, which were taken quickly (I've got some pretty decent tyres and suspension) then the light turned off. Oil level is fine, just below full. I must say I thought that low oil pressure and sparks may be related, and thats what worried me. High revs + high G's + stock sump baffling would = oil surge, yeah? that was my conclusion.
Re: Sparks coming out of exhaust... Mon, 09 May 2005 03:29 Go to previous messageGo to next message
Chances are the high-rpm thrashing loosened some carbon deposits in the combustion chambers, and that's what you saw coming out of the tailpipe.
setsuna
Re: Sparks coming out of exhaust... Mon, 09 May 2005 03:33 Go to previous messageGo to next message
or rust from exhaust.
ive seen this before recently.
(mates KE55 rolla)
bought it. thrashed it a bit n stuff Smile
yay $100 rolla! Smile
its fine, runs as a daily driver, with a bit of thrashing on weekends.
greenta22
Re: Sparks coming out of exhaust... Mon, 09 May 2005 03:40 Go to previous messageGo to next message
Norbie wrote on Mon, 09 May 2005 13:29
Grouse, mabe we should all have scheduled thrashings at regular intervals Very Happy
I think anything else shooting out the tailpipe would have had an adverse effect on performance, (ie. bits of rings or valves) which is something that I havn't noticed.
Thanks everyone.
Now off to build a baffled sump...
greenta22
Re: Sparks coming out of exhaust... Mon, 09 May 2005 03:42 Go to previous messageGo to next message
Thanks everyone.
Now off to build a better baffled sump...
joorsh
Re: Sparks coming out of exhaust... Mon, 09 May 2005 11:05 Go to previous message
I'm getting all misty-eyed just thinking about my POS N12 exa. It used to do roughly the same thing - cept it would normally spit the burning chunks out on whichever poor sod was unfortunate enough to be following me (haha Drav Razz).
In any case, I'm reasonably sure it was just chunks of old oil & carbon deposits. The puss-bucket used to blow a lot of smoke too (read: billow).
Previous Topic:ae86 JDM diff ratio
Next Topic:fuel cap issue
Current Time: Sat Oct 17 06:08:51 UTC 2026
Total time taken to generate the page: 0.014178991317749 seconds
