Toymods » Tech & Conversions » soarer tuning
indian
south east - melbourne
soarer tuning Mon, 09 May 2005 03:04 Go to next message
guys i will be fitting a new intercooler soon (hybrid copy) a bit more boost around 12-14 psi plus doing a 3 inch exhaust for the soarer and getting a pod filter , now i know for sure the tuning for the car will be out by the time its all put togeter ,
so after its all done should i get it tuned straight away or can i drive the car for a while
im thinking of getting an apexi safc to tune the car for the fuel and uppign the timing to 12 or 15 deg
any places in melbourne that tune the safc properly
im tryign to gat as much as i can outta the stock turbos
any suggestions about what im doing
[Updated on: Mon, 09 May 2005 04:28]
tyottsoarer
Gold Coast
Re: soarer tuning Mon, 09 May 2005 04:12 Go to previous messageGo to next message
Is this a 1jz-gte soarer or a 1g-gte soarer?
In the case of the 1j soarer you will be able to drive the car around without ever tuning it if that is all the mods your doing.
As far as advancing the timing on a 1j? You will need an after market unit to do this, and if you're going to buy an safc as well you might as well look at a power fc.
As for the limit of the stock turbos on a 1j ,most people will agree on about 230rwkw at 14 psi.
[Updated on: Mon, 09 May 2005 04:13]
indian
Re: soarer tuning Mon, 09 May 2005 04:15 Go to previous messageGo to next message
sorry the car is a gz20 (1g-gte) soarer
i though this was in the technical forums Confused
tyottsoarer
Gold Coast
Re: soarer tuning Mon, 09 May 2005 04:16 Go to previous messageGo to next message
My bad about the tech thing, I had 2 windows open
hickoz_bro
Re: soarer tuning Thu, 12 May 2005 23:14 Go to previous messageGo to next message
you said on one thread you had an AFR of 12.6 down to 10????
if that's the case your running SHIT LOADS lean... 14.7 is perfect (stoicheometric value) my 18rc runs 14.7 on idle... after that it goes up from poor manifold vacuum (rich)...
fingers
Darwin
Re: soarer tuning Thu, 12 May 2005 23:26 Go to previous messageGo to next message
hickoz_bro wrote on Fri, 13 May 2005 08:44
Don't you mean Rich?
I doubt your engine is running perfect stoich. Rolling Eyes
hickoz_bro
Re: soarer tuning Fri, 13 May 2005 00:31 Go to previous messageGo to next message
believe it or not... it was running perfect stoich, on the gas analyser we had, but only on idle... at 2 grand it was a different story... went heaps rich... dropped to 10ish...
and yeah... your right, i did mean rich Razz
Chris Davey
sunny coast, qld
Re: soarer tuning Fri, 13 May 2005 01:20 Go to previous messageGo to next message
I would just get the SAFC and lean it out to about 12:1 and probably wouldn’t bother with ignition. Does the 1g have knock sensors?
indian
Re: soarer tuning Fri, 13 May 2005 01:21 Go to previous messageGo to next message
lollllll, i was doubting myself when u said that stuff just then as i donyt have the power graph on me now , but its at home i will post it up when its scanned
i thibk the 1g- gte has knock sensors
[Updated on: Fri, 13 May 2005 01:25]
HyDrA
Adelaide, SA
Re: soarer tuning Fri, 13 May 2005 01:25 Go to previous message
Chris Davey wrote on Fri, 13 May 2005 10:50
I would just get the SAFC and lean it out to about 12:1 and probably wouldn�t bother with ignition. Does the 1g have knock sensors?
Two of them Smile
Previous Topic:Ra28 ENGINE OPTIONS (Help?)
Next Topic:compatability question
Current Time: Sun Oct 18 04:35:56 UTC 2026
Total time taken to generate the page: 0.0057210922241211 seconds
