Toymods » General Car Talk » 1jzgte 5 speed manual gearbox
dorifto_vip
1jzgte 5 speed manual gearbox Mon, 09 May 2005 03:39 Go to next message
Whats the average going price for a 1jzgte 5 speed manual gearbox and is it cheaper to get it with the engne or to buy it
seprate?
-Andrew
[Updated on: Mon, 09 May 2005 03:40]
Re: 1jzgte 5 speed manual gearbox Mon, 09 May 2005 03:46 Go to previous messageGo to next message
Are we talking R154, in that case its $1200-$1500
Or the 2JZGE W58 - $800-$1000
Or the older W58 - $300-$500
dorifto_vip
Re: 1jzgte 5 speed manual gearbox Mon, 09 May 2005 03:50 Go to previous messageGo to next message
um.....m not sure
soemthng that can take some abuse but not over the top in price...its for a conversion in an mx73 cressida.
what would you recomend?
Re: 1jzgte 5 speed manual gearbox Mon, 09 May 2005 03:59 Go to previous messageGo to next message
Depends how you want to drive, and how much you want to spend.
W55/57/58 will last the power, providing you treat it nicely.
If you want to drift it and slam it through the gears, get an R154.
dorifto_vip
Re: 1jzgte 5 speed manual gearbox Mon, 09 May 2005 04:07 Go to previous messageGo to next message
would i be able to get the manual box cheaper if get it with the engine? Are they all a straight boltup to the engine? I thought the 2jz had a 6 speed not a 5 speed? the 2jz w58 seems to be the one that intrests me the most
Re: 1jzgte 5 speed manual gearbox Mon, 09 May 2005 04:14 Go to previous messageGo to next message
2jzgte has 6 speed, the 2jzge has 5speed (the earlier 2jzge's anyway).
manual 1jzgte cuts are like 3500-4000ish
auto ones can be had for 1500-2000.
Manual ones come with flywheel and clutch.
You do the maths.
dorifto_vip
Re: 1jzgte 5 speed manual gearbox Mon, 09 May 2005 04:17 Go to previous messageGo to next message
what about just the engne and gearbox on its own not a cut cus thats all need...and al the stuff to make it run
Re: 1jzgte 5 speed manual gearbox Mon, 09 May 2005 04:19 Go to previous messageGo to next message
You are better off getting a cut if you want to use factory ecu.
Most cuts are the same price as a motor/box/ecu if they don't come with brakes and panels.
Get on the phone, ring around.
dorifto_vip
Re: 1jzgte 5 speed manual gearbox Mon, 09 May 2005 04:20 Go to previous messageGo to next message
will do
thnaks for all your help
much appreciated
i2obert
Re: 1jzgte 5 speed manual gearbox Tue, 10 May 2005 09:37 Go to previous messageGo to next message
also remember it depends on what version 1jz you get to the price i been looking for a jzx81 and a jzx90 halfcut and geessuuess there hard to find lol
tyottsoarer
Gold Coast
Re: 1jzgte 5 speed manual gearbox Tue, 10 May 2005 10:07 Go to previous messageGo to next message
recently bought and installed one of these into my soarer. Box with the pedals flywheel and tail shaft cost me $2000
dorifto_vip
Re: 1jzgte 5 speed manual gearbox Tue, 10 May 2005 23:10 Go to previous messageGo to next message
tyottsoarer wrote on Tue, 10 May 2005 20:07
how much should a be saving for the whole conversion? around 5-6k?
Re: 1jzgte 5 speed manual gearbox Wed, 11 May 2005 00:35 Go to previous messageGo to next message
Depends how much you want to spend on a clutch/flywheel.
dorifto_vip
Re: 1jzgte 5 speed manual gearbox Wed, 11 May 2005 01:33 Go to previous messageGo to next message
i want fairly good ones but nothing over the top
Re: 1jzgte 5 speed manual gearbox Wed, 11 May 2005 01:41 Go to previous messageGo to next message
You can normally get a JZA70 conversion kit (box, flywheel, clutch, pedals, tailshaft etc) for about the $2000-$2500 mark.
Almost everything should bolt in.
Pedals will need to be modded a bit.
dorifto_vip
Re: 1jzgte 5 speed manual gearbox Wed, 11 May 2005 01:53 Go to previous messageGo to next message
with a 1jz in an mx73 should i upgradethe radiator and is there room for a frontmount oil cooler and IC
Re: 1jzgte 5 speed manual gearbox Wed, 11 May 2005 01:59 Go to previous message
Plenty of room, radiator should be fine unless you start pumping 20psi of boost.
Just get it cleaned.
Previous Topic:How Do I Post Up Videos
Next Topic:what wheels should i look for
Current Time: Thu Nov 19 09:31:26 UTC 2026
Total time taken to generate the page: 0.0062539577484131 seconds
