Toymods » Tech & Conversions » Turbo
chaser94
May 2005
Turbo Mon, 09 May 2005 11:02 Go to next message
hey there guys i'm after a turbo to put onto my 1jz. I want to have at least 1 bar of boost by 3800-4000 and i want to run around 18psi, and make 280-290 rwkw. I was wondering what turbo could achieve this? thanks heaps
4agte
Toronto, Downtown
Re: Turbo Mon, 09 May 2005 11:04 Go to previous messageGo to next message
t04s
4agte
Toronto, Downtown
Re: Turbo Mon, 09 May 2005 11:06 Go to previous messageGo to next message
http://www.importbitz.com/turbo.htm
alltho its meant for a 7mgte nothing a custom manifold wouldnt fix
Re: Turbo Mon, 09 May 2005 11:14 Go to previous messageGo to next message
GT35?
4agte
Toronto, Downtown
Re: Turbo Mon, 09 May 2005 11:15 Go to previous messageGo to next message
with a turbo capable of flowing that much air you should make quite decent boost from 3000 rpm on the 2jz
YelloRolla
On your mum!
Re: Turbo Mon, 09 May 2005 12:33 Go to previous messageGo to next message
The target requires about 550 engine hp (based on 30% drivetrain loss).
Look toward a GT30 rated at this approx power. You should be able tomake the boost at target RPM relatively easily with a 0.82 turbine.
Ultimately the decision is yours, so continue to research whatever info you can find.
peeack
Re: Turbo Tue, 10 May 2005 03:30 Go to previous messageGo to next message
A bloke in Newcastle makes that sort of power out of a Garret GT35-R, should look into that.
..J..
opening a can of whoop ass
Re: Turbo Tue, 10 May 2005 04:27 Go to previous messageGo to next message
0.70 front cover with a 52mm front wheel. no bigger. rear housing say 0.82 with a p trim exhaust wheel.
GT30 would be ideal. the power you are after is as mush as you will make with factory cam shafts on your average dyno. they run out of lift which many 1j owners are finding.
if you are running a manual box that figure should be easy.
but also factor in a ECU, injectors waste gate, manifold and the little things like oil and water lines fuel rail. it adds up fast.
sxturbo
Central Coast
Re: Turbo Tue, 10 May 2005 10:06 Go to previous message
i have a turbo you can buy, its brand new. i bought it but have decided it is a little big for what i want.
it is a t70 the ones they have on www.toofast2furious.com
you can have it for $800
and you pay for postage
Previous Topic:Escort engine mounts???
Next Topic:mkII Cressida wiring
Current Time: Fri Oct 23 04:04:30 UTC 2026
Total time taken to generate the page: 0.0054938793182373 seconds
