Toymods » Tech & Conversions » JZZ30 ECU Pinouts (Urgent)
ashsupra
Perth, WA
May 2005
JZZ30 ECU Pinouts (Urgent) Tue, 10 May 2005 02:37 Go to next message
Does anyone know the pinouts for the JZZ30 ECU ?
Mine has the 4 plugs (34P, 22P, 16P, 28P) in the back of it (Part # 89661-24281).
I urgently need to find out how to extract the check engine / error codes out of it as I am having a troublesome Mad misfire issue.
Thanks Smile
Ash
Re: JZZ30 ECU Pinouts (Urgent) Tue, 10 May 2005 03:17 Go to previous messageGo to next message
Start here.
http://www.toymods.org.au/Repository
Then try here
http://www.sixworks.com.au/html/diagrams.html
Re: JZZ30 ECU Pinouts (Urgent) Tue, 10 May 2005 03:18 Go to previous messageGo to next message
More specifically
http://www.sixworks.com.au/1JZGTE__JZZ30__pinouts. pdf
Re: JZZ30 ECU Pinouts (Urgent) Tue, 10 May 2005 03:19 Go to previous messageGo to next message
16P, 4pin top row, 2nd from the middle - W
[Updated on: Tue, 10 May 2005 03:20]
ashsupra
Perth, WA
May 2005
Re: JZZ30 ECU Pinouts (Urgent) Tue, 10 May 2005 03:41 Go to previous messageGo to next message
You legend Peewee ! Very Happy Very Happy
I've been searching for that for sooooo long.
Does this sound right :
So if I connect my test lamp to 12V at one end and "W" terminal at the other, then I should be able to get my error codes from the test lamp ?
Re: JZZ30 ECU Pinouts (Urgent) Tue, 10 May 2005 03:56 Go to previous messageGo to next message
Yes, W goes to ground inside the ECU
ashsupra
Perth, WA
May 2005
Re: JZZ30 ECU Pinouts (Urgent) Wed, 11 May 2005 05:31 Go to previous messageGo to next message
Mad Mad Mad Mad Mad No luck.
I tried to get the code straight out of the ecu, but couldn't get the lamp to blink once.
Does anyone know of another way to get the error codes ?
Re: JZZ30 ECU Pinouts (Urgent) Wed, 11 May 2005 05:35 Go to previous messageGo to next message
Turn the key ON, with the jumper not in there.
The light should be ON constant.
If its not, then the motor is not at rest.
Most likely the TPS is not at IDL
ashsupra
Perth, WA
May 2005
Re: JZZ30 ECU Pinouts (Urgent) Wed, 11 May 2005 05:47 Go to previous messageGo to next message
Sounds like a reasonable explanation peewee.
How can I test/check that ?
Re: JZZ30 ECU Pinouts (Urgent) Wed, 11 May 2005 05:49 Go to previous messageGo to next message
http://www.supratsrm.com
Look up 7mgte TPS
Should be near enough the same.
[Updated on: Wed, 11 May 2005 05:49]
ashsupra
Perth, WA
May 2005
Re: JZZ30 ECU Pinouts (Urgent) Wed, 11 May 2005 06:29 Go to previous messageGo to next message
Can anyone confirm the terminals' and readings you should get when testing a 1JZGTE TPS ?
Re: JZZ30 ECU Pinouts (Urgent) Wed, 11 May 2005 06:39 Go to previous messageGo to next message
Play around with the TPS and a multimeter.
Its only 4 pins, work it out.
You can't blow it up.
ashsupra
Perth, WA
May 2005
Re: JZZ30 ECU Pinouts (Urgent) Wed, 11 May 2005 06:45 Go to previous message
I have the uncanny ability to blow stuff up with the greatest of ease.
I enjoy working on cars myself, but I do worry about doing the wrong thing and making more problems.
Previous Topic:200k+ 4age reliability
Next Topic:LPG on 4AGE
Current Time: Thu Oct 22 04:52:38 UTC 2026
Total time taken to generate the page: 0.0065641403198242 seconds
