Toymods » Tech & Conversions » 7AFE -> 7AFZE?
birdie
Coalstoun Lakes
7AFE -> 7AFZE? Tue, 10 May 2005 04:14 Go to next message
Hi all, I have a 97 Rolla Seca Conquest with a 7AFE. i have looked into doing a full turbo upgrade a while ago and all that but that was going to cost too much. :S
So I had an idea the other day, could I use the S/C of the 4A-GZE, and run fairly low boost, 3-5psi on stock internals?
Could i steal the mounting hardware from a 4AGZE or would I need to do a custom job?
Ideally I wouldn't mind upping the power from the stock 85kw to 100-130kw which would make a fair difference.
malazn
Re: 7AFE -> 7AFZE? Tue, 10 May 2005 06:11 Go to previous messageGo to next message
custom mounting would be needed
the drive belt from the crankshaft also might have to be custom made but i wouldnt know..
you would need a aftermarket ecu and maybe bigger injectors to compensate for the extra pressure etc..
Johnny
Sydney, OZ
Re: 7AFE -> 7AFZE? Tue, 10 May 2005 09:48 Go to previous messageGo to next message
they will handle 7psi as this is what the sportivo(turbo)rolla's had, Standard 7A + i/c + bigger injectors.
Nope custom jobbie, as you'll find the S/C on the GZE sits where the A/C compressor is and also the Alternator will als be in the way as the GZE has this on the opposite side of the motor(rear near firewall). Another possiblity is remove the top half of the intake manifold and try and fit it here, AKA FF's Daewoo They did a few years back. What ever way $$$ are going to be high.
birdie
Coalstoun Lakes
Re: 7AFE -> 7AFZE? Tue, 10 May 2005 11:56 Go to previous messageGo to next message
Johnny wrote on Tue, 10 May 2005 19:48
7psi sounds even better Very Happy and thats with stock internals? Any idea how much power 7psi would yield. This sounds exciting Very Happy
Would I need a full aftermarket ECU? or could I just get a fuel computer? Bigger injectors, would i need a bigger fuel pump too? Is that all I'd need?
Ah ok, I'll have to talk to mate at http://www.raptorsc.com.au about the mounting, he might be able to do something up for me Very Happy
birdie
Coalstoun Lakes
Re: 7AFE -> 7AFZE? Tue, 10 May 2005 12:47 Go to previous messageGo to next message
I was reading http://www.toymods.org.au/4A-GZE_Tech.html and I found out that the 4AGZE s/c uses an electronic clutch to enagage and disengage the S/C. How would I do this on my 7AFE as i read the S/C will die prematurely if its ran constantly?
It also has a Air Bypass Valve so I guess I'd still need this. Do 2nd hand 4AGZE s/c normally come with this?
Also I read without an intercooler they can run hot. I have access to stock S13 CA18DET FMI, would that be sufficient?
birdie
Coalstoun Lakes
Re: 7AFE -> 7AFZE? Tue, 10 May 2005 23:44 Go to previous messageGo to next message
bump
Johnny
Sydney, OZ
Re: 7AFE -> 7AFZE? Wed, 11 May 2005 12:30 Go to previous messageGo to next message
Unfortunately, yes, that does create another problem, you'll need to configure some kind of readout from the TPS that turns it on and off, otherwise, I would just run it constant.
Quote:
Air Bypass Valve
It's just to let the air go around the butterfly... simliar to a Blow off valve in a turbo system (or was it waste gate?) you'll need to check this out, but it is necessary.
Grab it, alway useful what everyway you go!
birdie
Coalstoun Lakes
Re: 7AFE -> 7AFZE? Thu, 12 May 2005 07:33 Go to previous messageGo to next message
Johnny wrote on Wed, 11 May 2005 22:30
TPS as in Throttle Position Sensor? hmm, I wonder how hard that would be? I wonder if there is a electronic circuit in the silicon chip's electronic car circuit book.
Quote:
Air Bypass Valve
So I should try to get a S/C with this still on it?
My mate has it sitting there, and he said i could have it for nothing if i need it.
Will I need a full aftermarket ECU? or could I just get a fuel computer?
So I'll need bigger injectors, would i need a bigger fuel pump too?
and is that all I'd need?
CrAiGzEE
south of the big smoke
Re: 7AFE -> 7AFZE? Thu, 12 May 2005 12:30 Go to previous messageGo to next message
sounds to me you need to work out what ya want
cheap---reliable --- powerful you can only have 2!!! sounds to me you are looking for the first and third of these,
to do it properly u will need aftermarket computer for both timming and fuel
birdie
Coalstoun Lakes
Re: 7AFE -> 7AFZE? Mon, 30 May 2005 10:54 Go to previous messageGo to next message
Tim from Raptor SC suggested a GREDDY E-MANAGE for the ECU.
What injectors would be suitable?
Tim suggested a Hobbs switch (vacuum) for controlling the SC clutch.
So adding up some costs:
4AGZE SC: ~$400
Greddy EManage: $550
Hobbs Switch: $30
Injectors: ??? (depending on which ones I need)
Custom Fitting: ~$400
Other stuff: ??? (Boost Gauge $100)
Tune/Dyno Run: ??? (I guess a few of hundred?)
I have the option of adding the S13 Siliva Intercooler (Stock) (or splashing out and getting a nice polished FMI for bling factor Razz) but that will add extra costs for plumbing, and Tim didn't think it would make any difference when only running 6-7psi.
Anything else I have forgotten, or need to take note of?
Johnny
Sydney, OZ
Re: 7AFE -> 7AFZE? Mon, 30 May 2005 15:23 Go to previous messageGo to next message
Yeah as long as he's tuning it, They're just a bitch to tune from scratch when comparing to a Microtech, but when up and running they are good
GZE if they have the right impedance, or 7MGTE etc Autronic have a nice flow rate program that can be downloaded from the website
http://www.autronic.com/software/injsize.zip
You've covered all bases now Wink good luckk with it
birdie
Coalstoun Lakes
Re: 7AFE -> 7AFZE? Mon, 30 May 2005 23:30 Go to previous messageGo to next message
Johnny wrote on Tue, 31 May 2005 01:23
Yeah, he will be tuning it too (if i go through him, which most likely)
Ok, I have no idea about injectors. What is impedance? And how do i find out which ones would be suitable?
Sweet, now I just have to save up some money and get it done. I'll probably do my suspension first though (lower, and stiffer) (and check my brakes too)
kingmick
Banned by his request
moved to tamworth
Re: 7AFE -> 7AFZE? Tue, 31 May 2005 10:47 Go to previous messageGo to next message
for a naturally atmo engine 7age{not fe} is good but for superchargeing i would just put a gze with one of john's nevo pulley kits on! the cost etc just isnt worth it. even for an nat atmo engine it will cost a bit unless you do the work etc. the fe head js not very good for anything but saving fuel. just swap a gze with standard computer and nevo kit and smile.
mick
birdie
Coalstoun Lakes
Re: 7AFE -> 7AFZE? Mon, 06 June 2005 05:25 Go to previous messageGo to next message
If I was to get the rods shot-peened and nitrated, would that be enough to alow me to wind up the boost, or would the crank and pistons still be too weak?
How much does it cost to get shot-peening and nitration done?
EldarO
Perth, WA
Re: 7AFE -> 7AFZE? Mon, 06 June 2005 06:53 Go to previous messageGo to next message
7aFe
f = economy(narrow) head, in no way designed to produce excessive amounts of power.
Eldar.O.
birdie
Coalstoun Lakes
Re: 7AFE -> 7AFZE? Thu, 16 June 2005 23:13 Go to previous messageGo to next message
I''ll only be running 7PSI so its not going to be excessive ammounts of power.
Maybe at a later stage I might consider upgrading the motor, and putting a GE head on, upgrading the pistons, and strengthing the rods and crank.
kingmick: I'd have to get at least an AE101 4AGZE to put in my car, I'm not sure where I'll find them?
4agte
Toronto, Downtown
Re: 7AFE -> 7AFZE? Fri, 17 June 2005 01:16 Go to previous messageGo to next message
i would use the sc14 even on the 4agze the sc12 runs outta puff in the top end
edit: a sc14 on 7psi of boost should make some considerable power i wouldnt be supprised if it makes 130-140kw at the engine
you will need a decent exhaust bigger injetors and a fmic of some kind a 1gg intercooler comes to mind they cost 150 buks from the wreckers and are sufficient for low boost when front mounted you will also need an aftermarket ecu of some kind a noticed a greddy emange being mentioned this is the cheapest way to do it...
You might also need extractors for the 7afe to make the most of the s/c 4 into 1 and a 2 1/2 exhaust with a decent cat would be ideal
as mentioned above custom brakets will be needed to relocate anything that is on the intake side of the engine usually the a/c.
You may also need to upgrade the stock clutch to handle the extra torque.
When you think about it a turbo isnt going to cost you much more but a sc14 on a 7afe would be pretty cool
[Updated on: Fri, 17 June 2005 01:23]
Merudo
Central Coast, NSW
February 2005
Re: 7AFE -> 7AFZE? Fri, 17 June 2005 02:35 Go to previous messageGo to next message
EldarO wrote on Mon, 06 June 2005 16:53
7aFe
Eldar.O.
I've seen bill sherwood and cruzsida both say that the FE heads are in no way inferior to the GE heads.
EldarO
Perth, WA
Re: 7AFE -> 7AFZE? Fri, 17 June 2005 03:29 Go to previous messageGo to next message
taken from the "articles" page of the toymods index page.
"F - Narrow angle Twin Cam (economical head)"
Narrow angle meaning the ports and everything else are in a different poisition,
"G - Wide angle Twin Cam (sportier head)"
If they were exactly the same, why would toyota feel the need to engineer two different heads?
They may be similar, but the wider angle head is obviously better suited to performance application.
7afe is 1.8 litre isnt it? i assume its just a stroked 4a? i know nothing about these engines, but, it seems simple enough to swap the heads and ecu over, seeing as they *apparantly* are bolt up.
the 7afe/4age could probably only put up with 6-8 psi of boost on high compression setup before is fucks up, whats the point?
Buy a 4AGZE, swap it in, apart from the ecu, everything should *glide* right in.
Eldar.O.
Re: 7AFE -> 7AFZE? Fri, 17 June 2005 09:47 Go to previous messageGo to next message
7aFe
Eldar.O.
Tell y'what, I'll swap you my 4aGe for a 1gzFe, or if you really drive a hard bargain, a 3uzFe. Sound fair?
Johnny
Sydney, OZ
Re: 7AFE -> 7AFZE? Sat, 18 June 2005 01:46 Go to previous message
First, technically yes they are a stroked 4A, but to accomdate the extra stroke, the block is different it's 14mm taller. Also pistons are different, if you throw a GE head straight on to a FE block, you comp will be around 7.5:1, and even for F/I this would be way too and the thing would have to be on boost to go any where, You need to use the GE(or GZE) pistons to match that head... That's just the start.
Not if you use GZE pistons.
If it's an AE101 cut ande the car is and AE101,(which birdies is) You'll find it's all plug and play, by far this would be my number one choice if asked what engine in this car...
Previous Topic:STREEING box repairs
Next Topic:Engineers Supply's shop, open weekends in Sydney?
Current Time: Wed Oct 14 04:49:13 UTC 2026
Total time taken to generate the page: 0.030363082885742 seconds
