Toymods » Tech & Conversions » Timing for 4A-FC
PASHN8
Timing for 4A-FC Tue, 10 May 2005 05:52 Go to next message
Hey guys,
simple query, I have a '89 AE92 Corolla Seca with a carbied 4A-FC in it, I want to set the timing and base idle, as i'm sure the timing is way off. Sometimes it runs roughly for a second after I turn the key off, fuel consumption is terrible, and it has no power up hills etc..
I can't find the placard with the timing designations, I have a timing light, so can someone tell me what it should be set to from factory?
Any other suggestions welcome
Thanks,
Dino.
lucifer D
Re: Timing for 4A-FC Tue, 10 May 2005 06:07 Go to previous messageGo to next message
5 degrees advance if i can remember correctly. Also i think it states that the vacuum lines are to be disconnected from distributor and blocked.
PASHN8
Re: Timing for 4A-FC Tue, 10 May 2005 06:58 Go to previous message
Hope you have a good memory! Smile
Will give it a try, what is the significance of the removal and blocking of the dizzy vacuum lines?
Previous Topic:4k mods
Next Topic:JZA70 Digital Dash Wiring
Current Time: Fri Oct 23 22:40:44 UTC 2026
Total time taken to generate the page: 0.0081861019134521 seconds
