Toymods » Tech & Conversions » No Spark 1GGTE
badboybubby
On Probation
No Spark 1GGTE Tue, 10 May 2005 09:40 Go to next message
Ive put the motor back in and have power to the coil but no spark ? any idea where I should start looking ?
/me head butts wall Sad
[Updated on: Wed, 11 May 2005 08:33]
badboybubby
On Probation
Re: No Spark 1GGTE Wed, 11 May 2005 08:32 Go to previous messageGo to next message
HyDrA
Adelaide, SA
Re: No Spark 1GGTE Wed, 11 May 2005 09:02 Go to previous messageGo to next message
No spark at all? Look at the power source, and the dizzy plugs, check for bad wires. It should have no troubles working imho.
badboybubby
On Probation
Re: No Spark 1GGTE Wed, 11 May 2005 09:37 Go to previous messageGo to next message
Yeah it was all working when I pulled the engine out theres no spark straight outa the coil does it get its trigger though some sensor ?
Ive tried another coil and it does the same thing ?
Fattony
Re: No Spark 1GGTE Wed, 11 May 2005 13:40 Go to previous messageGo to next message
seems silly but you have prob forgot to put a ground wire somewhere, it can cause all stupid things with ignition
badboybubby
On Probation
Re: No Spark 1GGTE Wed, 11 May 2005 22:40 Go to previous messageGo to next message
all Ive really done is move the coil off a bracket something was on
on the left hand side near where the overflow bottle was
and mounted it on the strut tower so I could sit the afm lower maybe thats it
Could the coil not be grounded properly ?
badboybubby
On Probation
Re: No Spark 1GGTE Thu, 12 May 2005 03:00 Go to previous messageGo to next message
How does the coil get its ground?
HyDrA
Adelaide, SA
Re: No Spark 1GGTE Thu, 12 May 2005 03:54 Go to previous messageGo to next message
Spark plugs.
Just test spark by plugging a spark lead into a sparkplug and rest the plug on the head/intake pipework.
badboybubby
On Probation
Re: No Spark 1GGTE Thu, 12 May 2005 04:27 Go to previous messageGo to next message
Yeah thats how i worked out it had no spark Very Happy i even did it straight outa the coil im thinking its missing a signal from something ?
badboybubby
On Probation
Re: No Spark 1GGTE Thu, 12 May 2005 04:28 Go to previous messageGo to next message
Ive grounded the block and the battery ?
Re: No Spark 1GGTE Thu, 12 May 2005 04:49 Go to previous messageGo to next message
spark control is (in a nutshell):
sensors in dizzi provide timing signal(s) to ECU - ECU/loom passes on raw timing signals to the ignitor - ECU also generates a spark advance signal based on engine load/temp/speed/etc - ignitor uses both (plus does some dwell control) to work out when to fire the coil.
so, tracing back from that, it could be:
coil
igniter
wiring from ECU to ignitor
wiring from dizzi to ECU
sensors in dizzi
i'd suggest gettin a check-engien light working and seeing if the ECU is sending any error codes to you.
Also - i'd be getting a wiring diagram for the engine and double checking everything.
badboybubby
On Probation
Re: No Spark 1GGTE Thu, 12 May 2005 04:59 Go to previous messageGo to next message
Apparently the igniter/coil cets its ground from the igniter casing I dont think I bolted it down well enough when I moved it Embarassed
Damm tek screws
HyDrA
Adelaide, SA
Re: No Spark 1GGTE Thu, 12 May 2005 08:10 Go to previous messageGo to next message
Eew tek screws Crying or Very Sad
badboybubby
On Probation
Re: No Spark 1GGTE Thu, 12 May 2005 12:37 Go to previous messageGo to next message
All tremble before the master of bodgieness Very Happy
badboybubby
On Probation
Re: No Spark 1GGTE Fri, 13 May 2005 10:56 Go to previous message
Ok im posting a case closed for anyone else that has this drama I remounted the coil solidly and it was all good apparently the coil grounds throught its mounts Very Happy
Previous Topic:3sgte boosting up prob.. Now Wit Pics...
Next Topic:big end bearing in No4 cylinder 4age (20v)
Current Time: Sat Oct 17 13:34:10 UTC 2026
Total time taken to generate the page: 0.0062181949615479 seconds
