Toymods » Tech & Conversions » 1990 MR2 Turbo upgrades
SW20R
1990 MR2 Turbo upgrades Tue, 10 May 2005 11:13 Go to next message
What bolt on kits are available? I've been trying to search on google.. but no avail?
Looking for a good Turbo upgrade.. something close to 150kw-180kw at the wheels. looking for more midrange then top end as it will be for circuit/handling.
-==L=a=N=c=E==-
Brisbane, Queensland
Re: 1990 MR2 Turbo upgrades Tue, 10 May 2005 11:53 Go to previous messageGo to next message
Your not looking hard enough then Smile
180rwkw can be had with the stock turbo and a few simple mods. Surely you want more then that?
If you want quicker spool then hunt down a CT20B off a gen3 motor.
Hunty
Re: 1990 MR2 Turbo upgrades Tue, 10 May 2005 23:40 Go to previous messageGo to next message
180rwkw with a stock ct26?
what mods? i have boost set to 12psi, full 3" exhaust including dump pipe to a hi flow cat n straight thru cannon style muffler, pod filter and cool air intake set up and an intercooler water spray system setup, i'd say id be making about 125-130kwatw
how would i go about gettin more than that with out upgrading the turbo and or cams.
MR. 2
Parramatta
Re: 1990 MR2 Turbo upgrades Wed, 11 May 2005 06:10 Go to previous messageGo to next message
lance is on the money, easy to get the power out, get a aftermarket computer a good tuner and high flow your turbo and do full 3" exhaust including dump pipe to a hi flow cat n straight thru cannon style muffler, pod filter and cool air intake set up and an intercooler water spray system setup. after this you couldnt expect any less then 190 - 200rwkw. and if you got less your tunner is crap.
when i did high flow and IC and EMS + 3" exhaust i, pod filter and cool i got 190 something rwkw @ 19 PSI so its very achive able. bolt on kits are good for making alot more power, use what you have if thats all the power you want.
Hunty
Re: 1990 MR2 Turbo upgrades Thu, 12 May 2005 00:58 Go to previous messageGo to next message
so its all about the ECU management, makes sense the thing runs soooo rich when on boost.
19psi?? on a ct26? yikes!
MR. 2
Parramatta
Re: 1990 MR2 Turbo upgrades Thu, 12 May 2005 03:03 Go to previous messageGo to next message
Hunty if thats aimed at me yes its running rich at the moment because i was running the head in again, + everything else new and im just too lazy to go back and get it tuned again, i waiting to get a few more things before i re tune the car. So i know its very very rich at the moment, i know this cause everyone tells me LOL.
hahaha
Hunty
Re: 1990 MR2 Turbo upgrades Thu, 12 May 2005 03:28 Go to previous messageGo to next message
lol nah sorry man i mean my car is running rich, i dont have any aftermarket management just the stock ecu and the mods listed above
MR. 2
Parramatta
Re: 1990 MR2 Turbo upgrades Thu, 12 May 2005 03:56 Go to previous messageGo to next message
well your car shouldnt be running rich!, not unless the afm has been screwed around with.
Hunty
Re: 1990 MR2 Turbo upgrades Thu, 12 May 2005 05:34 Go to previous messageGo to next message
well crap loads of black smoke out the exhaust when ya hit boost, will know for sure once i get it on the dyno but i wouldnt be surprsed if the A/F is sumthing like 10:1 at WOT
i know its not a corolla but its a pig on fuel to, like i cant get more than about 320k's out of a tank, city driving, not thrashing it but not driving like a granny either.
Yian
Lwr Templestowe, Melbourne
Re: 1990 MR2 Turbo upgrades Thu, 12 May 2005 05:42 Go to previous messageGo to next message
Hunty wrote on Thu, 12 May 2005 15:34
I had that problem when there was a boost leak. Ran fine when off boost, but when boosting, air would leak out through a hose that wasn't clamped properly and made it run pig rich. Clouds of black smoke behind me going uphills Razz
Joshstix
Toymods Vice President
Re: 1990 MR2 Turbo upgrades Thu, 12 May 2005 07:18 Go to previous messageGo to next message
Every 3SGTE I've seen on the dyno, with stock management, gets 10.0 or lower AFR when they come on boost.
Actually no I do know of one which didn't but it's a Gen3 so the management is completely different.
[Updated on: Thu, 12 May 2005 07:19]
-==L=a=N=c=E==-
Re: 1990 MR2 Turbo upgrades Thu, 12 May 2005 11:04 Go to previous message
http://www.mrcontrols.com/primers/power.htm
Have a look at this power primer. Now take it as a grain of salt but he goes thru and explains where power can be made and what you need to do to make that power.
As MR. 2 has said, thats basically what you need to do to get close to 180rwkw.
Intake,Exhaust,Intercooler,Boost,ECU. And if you ask me, those are logical upgrades before even looking at a new turbo.
Previous Topic:Celica ST162 Conversions
Next Topic:changing ae82 starter motor
Current Time: Sat Oct 17 22:34:59 UTC 2026
Total time taken to generate the page: 0.0093381404876709 seconds
