Toymods » Tech & Conversions » How much brake fluid?
davedave
How much brake fluid? Wed, 11 May 2005 01:10 Go to next message
I want to do a full bleed of my aw11 brake and clutch. How much fluid do you think I need?
I'm going to go with a DOT 4 variety as it seems to be the general consensus (use DOT4 and change it often), am I on the right track?
Also, from what I've read when doing the brakes: you bleed the furthest brake from the master cylinder first (and so on until you've done them all) and you bleed until you see the new fluid. How noticeable will the new fluid be?
Dave
bbaacchhyy
Re: How much brake fluid? Wed, 11 May 2005 01:33 Go to previous messageGo to next message
davedave wrote on Wed, 11 May 2005 10:40
Dave
Get 2 x 500ml bottles.
The colour change will/should be quite noticeable.
STR8 2.8
if its your first time id suggest buying around 1.5L
correct, start furthest from the cylinder and work your way toward.
you may not be able to see the difference in fluid if the hose/bottle is not perfectly transparent, so just run a few hundred ml's through.
[Updated on: Wed, 11 May 2005 01:38]
davedave
Re: How much brake fluid? Wed, 11 May 2005 01:34 Go to previous message
sweet, thanks fellas
Previous Topic:toyota camry timing belt installation
Next Topic:Problem with 3S-GE
Current Time: Sat Oct 17 19:04:52 UTC 2026
Total time taken to generate the page: 0.0041790008544922 seconds
