Toymods » Tech & Conversions » Oil Cooler?
1jzmx83
Oil Cooler? Fri, 22 November 2002 02:34 Go to next message
Pretty stupid question, but whats the difference between an oil cooler and a trans cooler? I was told they are one in the same?
MR. 2
Parramatta
Re: Oil Cooler? Fri, 22 November 2002 03:09 Go to previous messageGo to next message
an oil cooler cools the motor oil and the tranny cooler cools the gearbox oil simple really! any take care
1jzmx83
Re: Oil Cooler? Tue, 03 December 2002 05:37 Go to previous messageGo to next message
Thanks for the reply, but I was more after the differences in the coolers them self, not thier funtions. I have sinse found out that they are one in the same. An oil cooler can be used as a trans cooler and vice versa. I bought 2 identical units, used one for transmission and one for oil.
frebbles
Re: Oil Cooler? Sat, 07 December 2002 18:28 Go to previous messageGo to next message
Depending on where it is in the line of things, I'm assuming after the oil pump...The oil cooler will handle a lot more pressure as oil pressure gets a lot higher than a trans cooler...I presume you could use an oil cooler as a trans cooler, however not as good an idea the other way around...I might be slightly wrong here...But seeing as though no one has replied, I thought I'd add my thoughts.
SUPRAGTE
North Sydney
Re: Oil Cooler? Sun, 08 December 2002 09:21 Go to previous message
Transmission coolers traditionally have smaller inlet/outlet lines hence have less overall flow. Engine oil coolers have larger inlet/outlet lines.
Previous Topic:1984 MX62 Cressida EFI Fuel Pump
Next Topic:73 Celica ST Performance parts
Current Time: Thu Nov 19 21:08:18 UTC 2026
Total time taken to generate the page: 0.0064358711242676 seconds
