Classifieds » Engines, Accessories and other Mechanicals » Big box of T50 parts - FREE
Henn
Rosanna, Melb
Big box of T50 parts - FREE Wed, 11 May 2005 14:13 Go to next message
I have essentially two T50s in bits.
One was a AE86 box with teeth missing off second and a rooted input bearing. And a rooted 2nd synchro.
The other is a complete TE72 box. Was in perfect working condition when I decided to rip it apart.
Both boxes are FULLY disassembled and parts are neatly labelled in ziplock bags. So if you want anything it's yours. Will send if you make it worth my while.
Hen
PS, I'm sure someone will ask, so AE86 box has better input shaft bearing and more output splines. TE72 box still has long extension housing, but smaller input bearing and fewer output splines. And no, you can't build one good box out of the two... otherwise I would have.
TerryOBeirne
Redbank Plains,near Ipswi...
Re: Big box of T50 parts - FREE Thu, 12 May 2005 00:17 Go to previous message
hi, can you please look carefully at the gears. do the tapered cones on the back of the gears, that the syncro rings rub on, press onto the gear ??> if they do, there will be an obvious spline on the inside. if there is no apparent join, then they are prob welded. I need some of the splined type, especially 2nd & 3rd gears. I'll pay CASH. pls PM me . thanks a lot
Previous Topic:SW20 MR2 RearHalf
Next Topic:T series Tail Shaft FS
Current Time: Thu Oct 22 03:06:51 UTC 2026
Total time taken to generate the page: 0.0042381286621094 seconds
