Toymods » Tech & Conversions » Engine Check Codes 42 & 43
bails81
icon9.gif  Engine Check Codes 42 & 43 Fri, 22 November 2002 06:36 Go to next message
Hey Guys
I've not long ago purchased a AE86 with a 4AGZE Very Happy .
The engine check light has been comming on every now and then.
I ran the diagnostics test and got back codes 42 and 43.
I cleared the codes from the computer and they came back again next time I took the car out.
Any Ideas on what's causing the codes and how do i fix it? The only problem Ive noticed with the car is the revs drop real low when i pull up at a intersection and sometimes the car stalls No No No .
PS
Code 42:
Vehicle Speed Sensor: No speed sensor signal to ECU when loaded driving condition with engine speeds 2000 to 5000 rpm for 8 seconds or more.
Code 43:
Starter: No starter signal to ECU when cranking in TEST mode.
Any help would be greatly appreciated.
AE82TwinCam
Canberra, ACT
Re: Engine Check Codes 42 & 43 Sat, 23 November 2002 07:43 Go to previous messageGo to next message
I get those codes as well Smile
I'd like to know how you fix them as well, I don't really have the cash at the moment to throw at an electrician who knows what he is doing..
-Andrew
jase
Re: Engine Check Codes 42 & 43 Sun, 24 November 2002 11:51 Go to previous message
With the speed signal, you probably need to find what car the gze was from. If the original had a cable driven speedo, the speedo is responsible for generating a signal that goes back to the computer. Usually.
If it's fully electric drive then i'm not sure if it is done that way.
Previous Topic:manafold sizes?
Next Topic:Brake Upgrades for AE-86
Current Time: Thu Oct 29 19:18:36 UTC 2026
Total time taken to generate the page: 0.041801929473877 seconds
