Toymods » Tech & Conversions » 4AGTE GearBox Upgrade
agp2002
Hobart
May 2005
4AGTE GearBox Upgrade Thu, 12 May 2005 03:59 Go to next message
Im putting together my 4AGTE and was wondering what other options i have for gearbox's i have a T50 at the moment but dont know what sort of power it can handle. Also it will be a drift only car so it might be driven a bit harsher than a road car. Last what diff / axle upgrades can i do, i was thinking a T18 like most ppl, but my mate suggested a hilux rear diff and axles, would this work??
Iain
ke35 - 4AGZE
Re: 4AGTE GearBox Upgrade Thu, 12 May 2005 05:53 Go to previous messageGo to next message
firstly, do a search this has been covered a lot...
as for gearbox, yes, supra 5-speed can be used with an adaping bellhousing.
and yeah you can use a hilux rear end....
what car is this in???
agp2002
Hobart
May 2005
Re: 4AGTE GearBox Upgrade Thu, 12 May 2005 05:58 Go to previous messageGo to next message
oppps forgot to meantion 1984 Toyota Corolla KE70.
TE72_Turbo
Re: 4AGTE GearBox Upgrade Thu, 12 May 2005 12:49 Go to previous messageGo to next message
The common 1410mm hilux diffs don't need shortening to fit the KE70 Smile They are pretty heavy though... How much power are you planning to make?
F series are only 5 mm wider too, so another option for a strong, but lighter diff than the hilux.
agp2002
Hobart
May 2005
Re: 4AGTE GearBox Upgrade Thu, 12 May 2005 13:07 Go to previous messageGo to next message
Well initally i wont be making much more than 110-120rwkW but would like to build up to about 160rwkW will i just be able to use standard axles?? if so i could weld the standard diff until i can afford a 2 way LSD.
Re: 4AGTE GearBox Upgrade Thu, 12 May 2005 14:13 Go to previous messageGo to next message
Go the Hilux diff - don't even THINK about using the original Bogwarmer, or a T diff. T50 is a waste of time too - W box from the outset is the only way.
agp2002
Hobart
May 2005
Re: 4AGTE GearBox Upgrade Thu, 12 May 2005 23:34 Go to previous messageGo to next message
Do people reckon with the extra weight from the hilux diff and W-series box will it affect the handling of the car, what sort of of gear box mounts will i need, just ones off an old supra if i choose a W55??
TE72_Turbo
Re: 4AGTE GearBox Upgrade Fri, 13 May 2005 10:24 Go to previous message
Welding your diff will be a good way to ensure that you WILL break axles Laughing Don't consider it unless you have time to waste & a lot of spares Smile
Previous Topic:3S-GE into TA22 research (renamed thread)
Next Topic:AE82 engine options?
Current Time: Sat Nov 21 04:04:25 UTC 2026
Total time taken to generate the page: 0.0059499740600586 seconds
