Toymods » Tech & Conversions » 1J Belt setup without AC and PS
Pube
Camden
1J Belt setup without AC and PS Thu, 12 May 2005 07:49 Go to next message
How have others gone about running a smaller accessory belt on their 1JZGTE. I Dont need a power steering pump or air con pump. I have thought of modifying the Alternator mount to pivot to act as a tensioner but would like to know what others have done. Any help please.
Skip
Re: 1J Belt setup without AC and PS Thu, 12 May 2005 08:05 Go to previous messageGo to next message
Just thinking about it quickly it would be an option to retain the tensioner etc. and just make a idler pulley where the PS pump was. Then size up a suitable (shorter length) belt.
Re: 1J Belt setup without AC and PS Thu, 12 May 2005 08:15 Go to previous messageGo to next message
skip's idea will probably save hassles - just mount a bracket & pulley up in place of p/s pump, then measure for what you need. I also considered this, but the p/s is a great system on my car (good feedback), so I didn't want to ditch it.
Chris Davey
sunny coast, qld
Re: 1J Belt setup without AC and PS Thu, 12 May 2005 08:31 Go to previous messageGo to next message
I am running my 1jz without AC & PS. I have moved the alternator to the passengre side. It has a bracket that allows the alternator to pivot. I also have a 2j water pump which has a different sized pulley.
Off the top of my head, my belt is 115cm 5 rib one. And that was lucky because the next step up was about 8cm bigger.
MR 1JZ
Re: 1J Belt setup without AC and PS Thu, 12 May 2005 08:42 Go to previous messageGo to next message
while we are on the topic of power steering and what not, I am curious as to the hydraulic fan pump thing connected to the waterpump, obviously I am not running the hydraulic fan but becuase I am not does that mean I dont have to block those two areas off or can i leave them open, what actually flows through there? i was thinking power steering fluid? or does it usually have its own resovoir, if it does then i dont need to do anything right?
Re: 1J Belt setup without AC and PS Thu, 12 May 2005 08:43 Go to previous messageGo to next message
You have to feed them back on each other and keep it full of fluid.
Otherwise the bearings will die in a couple of weeks.
MR 1JZ
Re: 1J Belt setup without AC and PS Thu, 12 May 2005 11:23 Go to previous messageGo to next message
CrUZsida wrote on Thu, 12 May 2005 18:13
hmmmm so i have to fill it, then route the hoses back onto each other...
ok thanks Very Happy
manmx83
Re: 1J Belt setup without AC and PS Thu, 12 May 2005 15:08 Go to previous messageGo to next message
If you are not running the hydraulic fan you can purchase a 2jzge water pump from toyota and do away with that cumbersome and messy set up.i heard here that they arent overly expensive.
I still have that stupid set up on my car,its on the list of "to do" Rolling Eyes
Chris Davey
sunny coast, qld
Re: 1J Belt setup without AC and PS Thu, 12 May 2005 15:24 Go to previous messageGo to next message
The pulleys are pretty expensive. I got mine from Giant tomato for a decent price though.
Re: 1J Belt setup without AC and PS Thu, 12 May 2005 16:58 Go to previous messageGo to next message
the pump itself is about $120 from memory.
the pulley goes for almost the same price, but if you can borrow one and take it to a machinist, they can make them up for $60 or less (or mine from gianttomato was anyhow)
MR 1JZ
Re: 1J Belt setup without AC and PS Thu, 12 May 2005 22:28 Go to previous messageGo to next message
I just spent 4 hours putting another 1JZGTE waterpump on, so i think ill give the change to a 2JZ one a mis for the time being, will do it eventually tho, any idea on what sort of fluid you put in the pump? I was just going to use power steering, is that ok?
ChuckLandwehr
Re: 1J Belt setup without AC and PS Sat, 14 May 2005 07:27 Go to previous messageGo to next message
Hiya Pube, I set up my 1J, without A/C and P/S. I used the standard belt tensioner, and a 1 metre 6PK belt. Alternator stayed in the original spot. Water pump was not an issue, as there was no fluid drive for cooling fan on my 1J. Drop me your email address, and I will send you a pic.
cheers Chuck.
MR 1JZ
Re: 1J Belt setup without AC and PS Sat, 14 May 2005 07:30 Go to previous messageGo to next message
MR 1JZ wrote on Fri, 13 May 2005 07:58
anyone?
Pube
Camden
Re: 1J Belt setup without AC and PS Sat, 14 May 2005 09:11 Go to previous messageGo to next message
Thanks ChuckLandwehr some pics would be great Shocked . Send to bibobowow@hotmail.com Cheers.
Re: 1J Belt setup without AC and PS Sat, 14 May 2005 10:29 Go to previous messageGo to next message
90% sure is power steer/ATF
MR 1JZ
Re: 1J Belt setup without AC and PS Sat, 14 May 2005 10:52 Go to previous message
thanks cruz, ill stick with the 90% Smile
Previous Topic:Searching for a 3TGTEU
Next Topic:T50 shifter modifications
Current Time: Sat Oct 17 03:01:06 UTC 2026
Total time taken to generate the page: 0.007011890411377 seconds
