Toymods » Tech & Conversions » What strength loctite on crank pulley bolt
HighRolla
What strength loctite on crank pulley bolt Thu, 12 May 2005 13:07 Go to next message
Anyone know a good one?
V8_MA61
Re: What strength loctite on crank pulley bolt Thu, 12 May 2005 13:08 Go to previous messageGo to next message
the red one
HighRolla
Re: What strength loctite on crank pulley bolt Thu, 12 May 2005 13:13 Go to previous messageGo to next message
There's heaps of red ones right? Will it make it super dooper hard to get off at the next 100k service?
gearb0x
Re: What strength loctite on crank pulley bolt Thu, 12 May 2005 14:07 Go to previous messageGo to next message
read the packets
they generally have a torque rating for what torque will break the seal
Just dont get the one where u have to heat the crank up with an oxy just to get the bolt out
EldarO
Perth, WA
Re: What strength loctite on crank pulley bolt Thu, 12 May 2005 14:08 Go to previous messageGo to next message
red is permanant AFAIK you cant get it off, unless you superheat to red hot temps.
not cool.
then again, the blue one is piss weak because its what we use on the motor screws for our RC Nitro motors.
Eldar.O.
ed_ma61
Lost in the K hole
Re: What strength loctite on crank pulley bolt Thu, 12 May 2005 17:45 Go to previous messageGo to next message
V8_MA61 wrote on Thu, 12 May 2005 23:08
the red one
EldarO wrote on Thu, 12 May 2005 23:08
the blue one
they have numbers you know, quote a few of them...
http://tds.loctite.com/tds5/search.asp?t=&Q_PR OP7=0&Q_PROP18=0&Q_PROP22=1576&submit1 =Search
Secoh
Re: What strength loctite on crank pulley bolt Thu, 12 May 2005 18:34 Go to previous messageGo to next message
Use Loctite 232 (or whatever the current generation is called) which is the pale blue stuff. It's called "Nut Lock". nut lock is strong enough to prevent vibrations or thermal expansion changes from shaking it loose, but still allow you to undo it again at a later date. If you use stud lock (red stuff) or bearing lock (green stuff) that fucker will never ever be removed again, avoid them except for their intended uses.
FWIW if you come across something some moron has used the wrong loctite on, heating it with a heat gun (or blowtorch) will free it right up in no time.
loctite is good shit but you have to use it right.
kingmick
Banned by his request
moved to tamworth
Re: What strength loctite on crank pulley bolt Thu, 12 May 2005 21:17 Go to previous messageGo to next message
why you using loctite on crank bolt? unless your going to be spinning the engine to 12000 rpm i wouldnt use it. better of buying a brand new bolt. has it been coming loose?
mick
HighRolla
Re: What strength loctite on crank pulley bolt Thu, 12 May 2005 21:29 Go to previous messageGo to next message
No - just doing a timing belt and about to reassemble it all. I was told to use loctite on the carnk pulley bolt and on the odler pulley bolt. The bolt i in good condition. I might ust use some weak stuff. I.e. the blue one.
I'll check it out at repco. I'm going to be doing everything up to the correct toque settings so it should be alright without it I guess
Secoh
Re: What strength loctite on crank pulley bolt Fri, 13 May 2005 05:45 Go to previous messageGo to next message
all the crank vibration (and there's a lot) ends up in the flywheel and the front pulley (aka harmonic balancer on bigger motors) so yes it's always a good idea to loctite the crank and flywheel bolts.
berad
Re: What strength loctite on crank pulley bolt Fri, 13 May 2005 06:11 Go to previous messageGo to next message
none of the loctites workd for my mini bike on the zorst ... disapointing
Starfire
Re: What strength loctite on crank pulley bolt Sun, 15 May 2005 02:02 Go to previous messageGo to next message
Get a new bolt.
You havnt said what type of engine you have but I got a new one from toyota for my 4AGZE and it was about $5
They had also upgraded it to a larger head and washer due to the standard one being a little weak.
shinybluesteel
melbourne
Re: What strength loctite on crank pulley bolt Sun, 15 May 2005 02:08 Go to previous messageGo to next message
loctite didnt work on your 'zorst because ALL loctites are broken down by heat (except loctite 102 maybeye, but that is just superglue anyway)
i'd reccomend getting a new bolt too, as main pulley bolts in many cars are torqued to yield when installed (thats plastic deformation, or permanant stretch)
Re: What strength loctite on crank pulley bolt Sun, 15 May 2005 02:25 Go to previous message
I used the loctite labeled for nuts or bolts, cannae remember which. more a precaution than required, but my crank pulley hasn't fallen off yet Smile
Previous Topic:maybe ecu burnt out
Next Topic:KE20 hubcaps fit on mazda 13" rims?
Current Time: Fri Nov 20 13:52:21 UTC 2026
Total time taken to generate the page: 0.016633987426758 seconds
