Toymods » Tech & Conversions » engineering and battery moves
engineering and battery moves Sat, 23 November 2002 09:18 Go to next message
I'm buying a non-engineered engine conversion supra... and I'm wondering do you need an engineers certificate for a battery move to the boot? 'cause I dont want to get it engineered, then find I have to have it done again whe the battery shifts.
also, do you need a proper filler bottle to get it engineered? at the moment it's got a coke bottle in there, because there's no room in the engine bay. that wont fit in until I move the battery... so yeah, any help much appreciated guys
Bugman
Re: engineering and battery moves Sat, 23 November 2002 10:31 Go to previous messageGo to next message
speak to an engineer.. but I doubt the coke bottle will pass.. so bes to do both the battery and fix the filler in one go..
EMP-2TG
Carlingford, Sydney
Re: engineering and battery moves Sat, 23 November 2002 10:37 Go to previous messageGo to next message
well as far as i know u have to get in engineered
mine is, its easy to get passed
just get a battery box from a marine shop
and bolt it in the boot
then put a hose to the outside(a side vent etc)
and thats it
Re: engineering and battery moves Sat, 23 November 2002 13:26 Go to previous messageGo to next message
how big is a battery box from a marine shop? my plan was to make up a custom one from perspex, and mount it in one of the side compartments the supra has (with a smaller battery of course)
the filler bottle might not be such an issue.. saw a 7M-gte MA61 tonight that had a tiny little filler bottle
Re: engineering and battery moves Sat, 23 November 2002 13:39 Go to previous messageGo to next message
There are a few different size battery boxes so you should'nt have a problem Cool
juzzo84
Hornsby, N.S.W
icon10.gif  Re: engineering and battery moves Sat, 23 November 2002 21:31 Go to previous messageGo to next message
I have move the batterey in my ta22 into the boot, using a batterey box, which i bought from auto one, the ones at the marine shop may be a little bit big, as boat batteries are often much larger than car ones. When i took the car to get it inspected for a blue slip he checked that the box was secure and that it had holes to breath and he said no worries.
JUZZO
EMP-2TG
Carlingford, Sydney
Re: engineering and battery moves Sat, 23 November 2002 23:52 Go to previous messageGo to next message
from my experience a marin shop is normally cheaper for this kind of thing, they come in 3 or 4 sizes so it wont be to big
should cost under $30, the also sell battery isolator switchs wich are always a good idea Smile
tanman
Re: engineering and battery moves Sun, 24 November 2002 00:42 Go to previous messageGo to next message
You could always use a Oddessy battery instead. They are smaller, lighter and can be mounted at any angle. They also require no outside vent.
Re: engineering and battery moves Sun, 24 November 2002 04:06 Go to previous messageGo to next message
I dont think the RTA discerns between lead-acid and dry cell... they require both to be vented outside the cabin.. typically illogical for the rta :\
on the subject of engineeering (sorta) my car is now 3 moths and a few days out of rego.. waht do I have to do to get it pink slipped now?
SUPRAGTE
North Sydney
Re: engineering and battery moves Sun, 24 November 2002 04:19 Go to previous messageGo to next message
Be sure to put a very chunky earth cable to the chasis. MA61's suffer majorly from poor/undersized earthing and causes lots of problems with the dash blanking out while having a few loads on at the same time like the heater fan, headlights and demister.
A relocation to the boot will cause a fair bit of voltage drop and could make the problem worse if you already have symptons. Just a friendly warning.
Re: engineering and battery moves Sun, 24 November 2002 04:23 Go to previous messageGo to next message
thanks for the heads up. I have heard that, but no electrical problems as yet. I'm doing it purely for the weight transfer.
furhter to the previous bit... can you just go straight for the pink slip, or do you need an rta inspection or some such?
EMP-2TG
Carlingford, Sydney
Re: engineering and battery moves Sun, 24 November 2002 04:40 Go to previous messageGo to next message
yeah you will need to get a Blue slip as well now
Re: engineering and battery moves Sun, 24 November 2002 05:38 Go to previous messageGo to next message
which involves/costs?
Re: engineering and battery moves Tue, 26 November 2002 02:21 Go to previous messageGo to next message
blue slip costs approx $75.. most dudes need it all day. It like a pink slip with a thourogh ID check (ie, engine nos, VIN, chassis etc etc)... and most guys will NOT LIKE anything modified without engineer's cert.!! Esp the battery thing.. and the engine.... make sure they are FULLY engineered else most guys will tell you to walk (bummer... but they can get reeeealy busted if they pass you)
and no you can't get a pink slip.. once you are a day past 3 months unreg... thats it.. u need a blue slip! call the RTA they will tell you who locally can do one for you
SUPRAGTE
North Sydney
Re: engineering and battery moves Tue, 26 November 2002 06:18 Go to previous messageGo to next message
Edited at Business request
[Updated on: Fri, 10 February 2006 00:08] by Moderator
Re: engineering and battery moves Tue, 26 November 2002 08:27 Go to previous messageGo to next message
I went to BG... they turned me down 'cause of the bumper bar. Hopefully can just sell it as is,and whoever buys it can patch up the bumper bar and get it blue slipped
he was only worrried about the sharp bits on it
Re: engineering and battery moves Tue, 26 November 2002 09:59 Go to previous messageGo to next message
ok, now that I've found out voltage drop oculd be a serious issue (thanks paul) can anyone recommend a good battery to use for this?
CrAiGzEE
south of the big smoke
Re: engineering and battery moves Mon, 30 December 2002 00:35 Go to previous messageGo to next message
what size cable do you guys recommend? when movinv to the boot?
Re: engineering and battery moves Mon, 30 December 2002 03:25 Go to previous messageGo to next message
The best and only answer is: Fit the biggest you possibly can!
When it comes to main battery power cable the biggest is best and there is no "ifs, buts or maybes"...
Purple_Beasty
New Zealand
Re: engineering and battery moves Mon, 30 December 2002 09:03 Go to previous message
and match it on the earth side, add extra earths if you can.
Previous Topic:How much oil in a R154
Next Topic:Brake upgrade
Current Time: Mon Oct 26 07:32:55 UTC 2026
Total time taken to generate the page: 0.0063619613647461 seconds
