Toymods » Tech & Conversions » Suzuki Swift wont rev over 2000
ytri
Preston
Suzuki Swift wont rev over 2000 Sat, 23 November 2002 11:10 Go to next message
All right guys, got a problem on a Swift GTI. Idles fine, but not over 2000rpm. As soon as it does, it chokes and splutters. The car can be driven, but again, as soon as it hits 2000rpm it dies in the ass. Any ideas???
rollaboy
Coffs
Re: Suzuki Swift wont rev over 2000 Sat, 23 November 2002 12:26 Go to previous messageGo to next message
Just a idea...Have you checked the timing??
Manny
Re: Suzuki Swift wont rev over 2000 Sat, 23 November 2002 12:47 Go to previous messageGo to next message
Common ailment for a stuffed TPS on a GTi
manipulate
Re: Suzuki Swift wont rev over 2000 Sat, 23 November 2002 14:37 Go to previous messageGo to next message
Yeah check the timing
that was what was wrong on my car
juzzo84
Hornsby, N.S.W
icon13.gif  Re: Suzuki Swift wont rev over 2000 Sat, 23 November 2002 21:34 Go to previous messageGo to next message
if its not the timing then you may have an issue with your valves, i saw this happen on my mates civic, it would get just under 3000rpm and then it would just shit itself.
JUZZO
St3ve_AE92
South of Wollongong
Re: Suzuki Swift wont rev over 2000 Sun, 24 November 2002 01:16 Go to previous messageGo to next message
Similar problem my sister is having with her new swift. not gti. 1.6L carby....
doesnt like to start, and when it does, if ya dont keep ya foot on the gas, it will stall. Rolling Eyes
any suggestions would be appreciated... c
cheers in advanced
Apollo
Brisbane, QLD, Australia
Re: Suzuki Swift wont rev over 2000 Sun, 24 November 2002 01:57 Go to previous messageGo to next message
Recon the carb.
ytri
Preston
Re: Suzuki Swift wont rev over 2000 Sun, 24 November 2002 04:36 Go to previous messageGo to next message
Hi, Yeah have checked the timming all seems to be ok - it really strange because the car was running fine yesterday morning.
sbyder
Ipswich QLD
Re: Suzuki Swift wont rev over 2000 Sun, 24 November 2002 10:31 Go to previous messageGo to next message
blow the fuel lines out with a compressor. "Could" be a bit of sh!t stuck in there. Numerous possibilities Smile
Ben
Matt_G
Re: Suzuki Swift wont rev over 2000 Mon, 25 November 2002 12:05 Go to previous message
I had a similar problem on my GTi it took ages to nut it out. Ended up being the TPS as Manny said very common fault on a GTi. Easiest way to find out is disconnect it the check engine light will come on but it should run above 2 grand, maybe a little rich. Failing that have you tried running a diagnostic using the shorting fuse in the fuse box? If you need the fault codes let me know and I can mail them to you. I think TPS was 22 from memory and 12 is no faults.
Hope this helps and if all else fails get a KE25 the're cheaper than a new TPS. Laughing
G
Previous Topic:Stock black wheel sizes
Next Topic:4agze looks hard to wire up
Current Time: Wed Oct 28 13:08:00 UTC 2026
Total time taken to generate the page: 0.007781982421875 seconds
