Toymods » Tech & Conversions » best to rebuild? 4age
LAA.80E
The realist ghetto area P...
April 2005
icon10.gif  best to rebuild? 4age Fri, 13 May 2005 05:18 Go to next message
just wanting to know is it better having the 4age with the larger sized crank or the smaller one, because i have the both and i just wanna get sum peoplez opinionz on what is best to rebuild?
thanks............
rxjohn
Melb VIC
Re: best to rebuild? 4age Fri, 13 May 2005 05:27 Go to previous messageGo to next message
if its only a std rebuild both types are ok,
if you building a performance engine go for the later 7 rib , bigger crank and rods with oil squirters under pistons, also has higher compression std.
feral4mr2
Bundaberg, Qld.
Re: best to rebuild? 4age Sat, 14 May 2005 13:35 Go to previous messageGo to next message
what are you doing? going boosted or staying na? the earlier 4age (40mm bigends one) would make a revvier na engine having lighter internals.
LAA.80E
April 2005
Re: best to rebuild? 4age Sun, 15 May 2005 23:56 Go to previous messageGo to next message
ummmzzzzz well im keeping it n/a so im not to sure on what to rebuild ??
thanks for the info guys....
LAA.80E
April 2005
Re: best to rebuild? 4age Mon, 16 May 2005 07:36 Go to previous messageGo to next message
how can i tell what a seven rib is , is that by looking at the bottom end block on the outside?!!!
feral4mr2
Bundaberg, Qld.
Re: best to rebuild? 4age Mon, 16 May 2005 11:27 Go to previous messageGo to next message
http://img134.echo.cx/img134/206/feral7ribs6lx.th.jpg
you can use either internals in the 7 rib block.
rxjohn
Melb VIC
Re: best to rebuild? 4age Mon, 16 May 2005 22:56 Go to previous message
look at outside, intake side of block and will see difference in ribbing in the later model 7 rib blocks
Previous Topic:AFM Limits
Next Topic:Question bout a 91 t.corolla body kit
Current Time: Fri Oct 30 01:01:58 UTC 2026
Total time taken to generate the page: 0.041338920593262 seconds
