Classifieds » Engines, Accessories and other Mechanicals » F/S Custom made turbo Manifold 3sgte Mr2 or Celica pics
charliemr2
February 2005
F/S Custom made turbo Manifold 3sgte Mr2 or Celica pics Fri, 13 May 2005 08:20 Go to next message
Stainless steel manifold tuned length tig welded and purged to suit mr2 sw20 or Celica gt4 to suit Garrett28 Turbo Cheap $280.00 ono
Call for more info 0411288027 Charlie
[Updated on: Tue, 14 June 2005 04:43]
Toobs
Re: F/S Custom made turbo Manifold 3sgte Mr2 or Celica Sat, 14 May 2005 00:12 Go to previous messageGo to next message
Which generation 3sgte?
Gen 3????
Flange type?
Suit internally gated or externally?
Pics?
sleeker162
Re: F/S Custom made turbo Manifold 3sgte Mr2 or Celica Sat, 14 May 2005 13:29 Go to previous messageGo to next message
pics
da_horse
Melbourne Australia
Re: F/S Custom made turbo Manifold 3sgte Mr2 or Celica Sun, 15 May 2005 11:52 Go to previous messageGo to next message
pics of the manifold. tuned length to within 20mm, will suit a t28, internally gated and will suit gen3. charliemr2 may clarify some of these details next time he's online. manifold is also heat wrapped.
Inside where pipes merge
http://users.tpg.com.au/adsl4ti6/charliemr2/inside_01.JPG
http://users.tpg.com.au/adsl4ti6/charliemr2/inside_02.JPG
External Pics
http://users.tpg.com.au/adsl4ti6/charliemr2/manifold_01.JPG
http://users.tpg.com.au/adsl4ti6/charliemr2/manifold_02.JPG
http://users.tpg.com.au/adsl4ti6/charliemr2/manifold_03.JPG
http://users.tpg.com.au/adsl4ti6/charliemr2/manifold_04.JPG
http://users.tpg.com.au/adsl4ti6/charliemr2/manifold_05.JPG
charliemr2
February 2005
Re: F/S Custom made turbo Manifold 3sgte Mr2 or Celica pics Tue, 14 June 2005 04:48 Go to previous messageGo to next message
price drop $250.00
da_horse
Melbourne Australia
Re: F/S Custom made turbo Manifold 3sgte Mr2 or Celica pics Tue, 14 June 2005 15:05 Go to previous messageGo to next message
Shocked Cheap! really good quality manifold, would be great for anyone wishing to upgrade from factory manifold.
Bump Smile
charliemr2
February 2005
Re: F/S Custom made turbo Manifold 3sgte Mr2 or Celica pics Sat, 02 July 2005 23:03 Go to previous messageGo to next message
hey guys the manifold is still 4 sale ,surely there must be someone who needs one ,,, Wink
davedave
Re: F/S Custom made turbo Manifold 3sgte Mr2 or Celica pics Sat, 02 July 2005 23:23 Go to previous messageGo to next message
I'm still not trusting the dodgy one I made (thanks again for the flange), I'm sure I'm going to have to pull it off and patch some things.
If I do get sick of fixing my pos though, I might try and chase this up if it's still available.
You mentioned that it with a t28 protruded less than the standard ct26 and manifold, am I correct?
With dump pipe attached, would you have any idea if it would clear the alternator in the celica position (see my above picture) and also the celica A/C (I think it's a little bigger than the MR2 one but located in the same place.
Also, do you still have the oil and water lines to connect this bad boy up?
Dave
[Updated on: Sat, 02 July 2005 23:27]
charliemr2
February 2005
Re: F/S Custom made turbo Manifold 3sgte Mr2 or Celica pics Sun, 03 July 2005 05:43 Go to previous messageGo to next message
Hi Dave, dont know if u would have any trouble with the alternator as mine is on the otherside under the intake manifold ,as in the sw20 mr2.
lt would certainly be further away from the firewall as apposed to the ct26 . Firstly why dont u move the alternator to the other side ,An alternator bracket shoudnt cost v,much it would also give u more room to work on the car l know that u would have to modify the wiring a little bit but ultimately it would be worth the effort .From what l could see ,u seem to have done a reasonable job on the manifold ,what exactly is the problem with it does it leak from poor welding or cracks ? lf l can help give me a call , 0411288027
Cheers Charlie
davedave
Re: F/S Custom made turbo Manifold 3sgte Mr2 or Celica pics Sun, 03 July 2005 17:07 Go to previous message
Long story, don't know if it leaks or not. Going to find out that when she gets running. I MIG'd it first up and took some dodgy advice and brazed a couple of areas I couldn't get to with the MIG. Anyways, took it out to my old mans and had him teach me a lesson with the oxy and I've gone over 'most' of the welds. I found a lot of holes around the MIG which leads me to believe there's probably still more I didn't find. And also, the areas with the braze are a bit contaminated by it.
I actually modified the wiring (SW20 loom) to get the alternator on that side. With the standard bracket I was lead to believe I would have had to relieve the rear corner to fit the alternator. I wasn't really ready back then to start experimenting too much.
Previous Topic:FS: TRD Quick Shift for AE86
Next Topic:13T 1.8L Its gone
Current Time: Tue Oct 27 00:49:18 UTC 2026
Total time taken to generate the page: 0.0079340934753418 seconds
