Toymods » Tech & Conversions » Need some info on 1/2JZ-GE
M.J.H
Need some info on 1/2JZ-GE Sat, 14 May 2005 09:24 Go to next message
I need to know what the dimensions for each motor are please.
I did a search and came up with about 750mm long and 350mm wide but need the height,as well as someone to confirm or deny the above numbers.
Also would a GTE inlet manifold fit the GE motors?My guess is they would but just need to be sure.
Thanks.
Re: Need some info on 1/2JZ-GE Sat, 14 May 2005 09:30 Go to previous messageGo to next message
I'll measure one up when I get home from work tomorrow morning. 750mm (+/- 10mm) is about right.
As for the GTE manifolds, no they don't fit. Totally different for intake and exhaust.
Re: Need some info on 1/2JZ-GE Sat, 14 May 2005 11:28 Go to previous messageGo to next message
My 2JZ-GTE is about 650mm wide including manifolds, but I suppose the GE would be a bit narrower.
Re: Need some info on 1/2JZ-GE Sat, 14 May 2005 12:19 Go to previous messageGo to next message
http://forums.toymods.org.au/index.php?t=msg&t h=68143&start=0&rid=363&S=139eed0b54dc 31b4361234b04f501aab
This thread might contain a small amount of useful stuff. What's the plan?
M.J.H
Re: Need some info on 1/2JZ-GE Sat, 14 May 2005 17:51 Go to previous messageGo to next message
mrshin wrote on Sat, 14 May 2005 22:19
thanks for the link i missed that on the search.
The plan is to put one in a clubman that a guy has but the chassiss is already built and designed for a crummydore V6.
I want to use the 1/2JZ-GE if possible but depends on size and wether they can be tuned to pass current emmisions.
Re: Need some info on 1/2JZ-GE Sun, 15 May 2005 06:42 Go to previous messageGo to next message
Might be a bit heavy for a clubman, they're an iron block and by no means a lightweight. Have you considered something like a 1MZ? Much lighter and far more compact than a JZ engine, and being more modern it would be easier to pass emissions. Food for thought.
Re: Need some info on 1/2JZ-GE Sun, 15 May 2005 08:49 Go to previous messageGo to next message
Something about a 3S gearbox mating to them as well - bellhousing might be worth investigating?
M.J.H
Re: Need some info on 1/2JZ-GE Sun, 15 May 2005 09:18 Go to previous messageGo to next message
Whats the 1MZ out of?
being road regoed it would come in heavy anyway so weight is not a huge factor.Was hoping to get it on the road at 6-700kg all up.
The engine bay measures 640 wide by 850 long and have to consider the steering and pedal ass on the right will cut into the width as well.
Still i'm open to all possible choices at the moment,just thought the JZ would be the go but if there is something better then i will check it out.
Re: Need some info on 1/2JZ-GE Sun, 15 May 2005 11:34 Go to previous messageGo to next message
MZ series V6s are all alloy. Also they are a 60* vee so quite compact.
[Updated on: Sun, 15 May 2005 11:35]
Re: Need some info on 1/2JZ-GE Sun, 15 May 2005 11:42 Go to previous message
M.J.H wrote on Sun, 15 May 2005 19:18
Avalon and late-model Camry. They're an awesome engine which unfortunately has been fitted to some pretty dull cars.
Previous Topic:How do I tell if my O2 sensor is a heated type or not?
Next Topic:BLITZ TURBO TIMER
Current Time: Fri Nov 20 14:10:38 UTC 2026
Total time taken to generate the page: 0.007457971572876 seconds
