Toymods » Tech & Conversions » Help me ID pipes (pictures)
Xinx
Help me ID pipes (pictures) Sat, 14 May 2005 15:36 Go to next message
Hi guys,
I got a few things I like to ask. Now this may seem very simple to some, but I just want to be sure that I connect everything correctly.
I've got a JDM ae86 fuel tank with 3 pipes coming off it I know that one must be the main that supply fuel to the engine, one return and what is the third one?
have a look at the picture can you ID them for me? I've put label on the pic to make thing easier.
http://users.tpg.com.au/yendor/ae86tank.jpg
Also can someone tell me what each of these pipe are
http://users.tpg.com.au/yendor/fuelline.jpg
Thanks guys
WHITCHY
Castle Hill
Re: Help me ID pipes (pictures) Sun, 15 May 2005 05:30 Go to previous messageGo to next message
I just battled the EFI conversion in my AE86, to know for sure what pipes do what, screw off the plate that the pipes are coming off, and pull this out, it will have your fuel pump attathed to it, then you will be able to see what the pipes do, the there will be one going from the top of the fuel pump (fatter one in the middle) and then there will be a pipe going down to about level with the middle of the pump, this is the return fuel line, and then one will just be poking down from the top this is the breather.
As for those other pipes...
#1 is the fuel feed for the fuel rail.
#2 is where the breather from your brake booster hooks up to
#3 is the return fuel line to your tank
#4 is a vacuum sensor
Hope that helps ya out!
Cheers.
-Whitchy-
berad
Re: Help me ID pipes (pictures) Sun, 15 May 2005 05:56 Go to previous messageGo to next message
the fuel tank
1 is the fuel feed as its a threaded line no clamps on that bad boy
and 2 or 3 as far as i know it doesnt mater one is return and the other runs to ur carbon canister.
[Updated on: Sun, 15 May 2005 05:57]
Xinx
Re: Help me ID pipes (pictures) Sun, 15 May 2005 09:54 Go to previous messageGo to next message
Ok thanks people, that what I thought as well. Just want a second opinion thats all. What about this breather line can someone explain to me its purpose does my original tank for the 4ac have one?
YelloRolla
On your mum!
Re: Help me ID pipes (pictures) Sun, 15 May 2005 10:29 Go to previous messageGo to next message
the breather line from your fuel tank ussually takes a convoluted trip around your vehicle to the charcoal canister, which will be mounted under the bonnet - yes your car will have one...
berad
dont think ur 4aC would... it just breaths into the carbon canister... i probly wouldnt block it up but run it somewhere as it wont leak fuel, it might be ok to block up but i wouldnt just in case ,
Re: Help me ID pipes (pictures) Sun, 15 May 2005 13:09 Go to previous message
no - anything from about 1976 onwards shoud have three lines from the tank to the engine bay:
main fuel feed (in an EFI car there's usually a fuel pump at or in the tank)
fuel return (end of port inside the tank will be in the upper part of the tank)
fuel vapour (vents to charcoal cannister - engine burns off petrol fumes, condensate either drains away on a carbi model or is sucked back to the tank in an EFI model)
i would suggest that all three be correctly plumbed up - the fuel vapour venting system, along with the correct petrol filler cap, helps maintain safe pressures in the fuel tank.
If you block off the vents, have a hard-sealing filler cap and then park car in the sun, you will get excess pressure built-up in the tank and will vent flamable fuel vapour via the petrol cap and also do weird things to the fueling system. You will also get petrol fumes at the rear of the car. If the tank is 100% full of petrol, you might even get petrol leaking out from the filler hole.
Conversely, the wrong charcoal cannister, or lines left open under the bonnet can lead to unpleasant petrol fumes at the front of the car.
Previous Topic:super charger not boosting
Next Topic:3K Timing and Ignition
Current Time: Fri Nov 20 12:57:49 UTC 2026
Total time taken to generate the page: 0.0048208236694336 seconds
