Toymods » Tech & Conversions » 18rc w/ 88230 head, timing chain kit?
ra40coupe
May 2005
18rc w/ 88230 head, timing chain kit? Sun, 15 May 2005 06:29 Go to next message
Hi guys, just new here.
Got a 18rc with the 18RG 88230 head, now i think ive got a slight problem, i checked my timing and when i spin the crank over theres about 12 degrees lag before the cams start moving.
what is exactly required with the 88230 head on the 18rc block, also what timing chain kit do i use??
im pulling it apart at work tomoro to see whats exactly wrong.
thank
brett_celicacoupe
townsville NQLD
Re: 18rc w/ 88230 head, timing chain kit? Sun, 15 May 2005 06:55 Go to previous messageGo to next message
ra40 coupe Cool
post up some pictures in the "members rides" section
people100
Rocklea qld
Re: 18rc w/ 88230 head, timing chain kit? Sun, 15 May 2005 09:46 Go to previous messageGo to next message
did u just slap a rg head on a rc bottum end. I SURE HOPE U SAY NO.
brett_celicacoupe
townsville NQLD
Re: 18rc w/ 88230 head, timing chain kit? Sun, 15 May 2005 10:47 Go to previous messageGo to next message
there are "ROLON" replacement chains available for them and they arent too dear.
if you ar still using your origional 18rc pistons then its gunna have VERY low compression Laughing even lower than an 18rc i would expect
Laughing
the 88230 18rg's need the high compression to give them any power
ra40coupe
May 2005
Re: 18rc w/ 88230 head, timing chain kit? Sun, 15 May 2005 11:04 Go to previous messageGo to next message
i bought this off a member of these forums.
im not sure what was done, just i got a lota play on the crank.
i cleaned and tuned the twin solex carbs and it seems to fly when i took it for a drive.
just my boss doesnt like how theres so much play between the crank and cams.
RA40Celica
Hobart
  chris_rg@jabber.org
Re: 18rc w/ 88230 head, timing chain kit? Mon, 16 May 2005 03:25 Go to previous messageGo to next message
is the timing chain loose?
maybe adjust the timing chain tensioner? this could be loose when the motor is stopped. it is hydraulic though and probably tightens up when oil pressure comes.
does it rattle much, when starting, or all the time?
theres a big bolt head on the left hand side of the head. there a little hole in the middle of it. using a screw driver you can push up this hole and feel the slack in the timing chain. adjust the big bolt until you have about 1.5mm of play.
if you have 18rg head on 18rc block, i hope you have 18rg pistons and oil pump at least.
ra40coupe
May 2005
Re: 18rc w/ 88230 head, timing chain kit? Mon, 16 May 2005 07:27 Go to previous messageGo to next message
well i took it for a run at work today and it seemed to tighten up at bit more then before. maybe 5-10 degrees.
there is no rattle. i had the tappet cover off and re tensioned the chain.
my engine number is 18R951****, i did a compression test and they only came up at around 110 on all 4.
ill have to find out what was done on the conversion.
[Updated on: Mon, 16 May 2005 07:28]
Mr DOHC
Re: 18rc w/ 88230 head, timing chain kit? Mon, 16 May 2005 08:59 Go to previous messageGo to next message
of course it'll go better with the RG head, but 110 is appauling, should be 170 minimum,
brett_celicacoupe
townsville NQLD
Re: 18rc w/ 88230 head, timing chain kit? Tue, 17 May 2005 04:28 Go to previous messageGo to next message
my 18rgU i tested the comperession and it was ~150psi
that was after 20 mins runniong since the rebuild so id reckon i would be a bit higher now its run in
Mr DOHC
Re: 18rc w/ 88230 head, timing chain kit? Tue, 17 May 2005 06:27 Go to previous messageGo to next message
170 for 18RG with 9.7, althouth there is no direct correlation between static compression and a compression test, 150 is ok for 8.7:1
ra40coupe
May 2005
Re: 18rc w/ 88230 head, timing chain kit? Tue, 17 May 2005 08:16 Go to previous messageGo to next message
so if im getting 110psi could that mean the RG pistons havent been used?
once i get it registered it will be rebuilt anyway. but as it is its still pretty quick, has no hassles frying the rears
Mr DOHC
Re: 18rc w/ 88230 head, timing chain kit? Tue, 17 May 2005 08:21 Go to previous messageGo to next message
where does it come on power, what rpm i mean
ra40coupe
May 2005
Re: 18rc w/ 88230 head, timing chain kit? Tue, 17 May 2005 08:26 Go to previous messageGo to next message
as soon as i tromp it. atm ive got the carbs off, once its running again ill test to see where it best performs.
from memory from about 2500 onwards its all balls
barned01
Re: 18rc w/ 88230 head, timing chain kit? Tue, 17 May 2005 14:35 Go to previous messageGo to next message
when i was pulling apart one 18rgeu, i noticed the small tensioner at the bottom of the block (common to 18rc's and 18rg') was actually stuck all the way in. this motor was completely shafted by the way.
it is however the first thing that popped into my head when you said there was a lot of slack from the time you moved the crank to the time the cams started moving.
.....although another thought also......
other theory is the engine rotates in a clockwise direction facing from the front of the car and if you are rotating it by hand after it has finished running and you rotate the engine in an anticlockwise manner then it would slacken the timing chain off before tightening again possibly even by about ~12 degrees...
umm compression could be down due to timing on exhaust and intakes being out by a bit...????
and i just got just over 150psi using 88251 pistons (8.7 i think) after rebuilding mine with an old 18rc block so mr. DOHC is right on the money i would say.
ra40coupe
May 2005
Re: 18rc w/ 88230 head, timing chain kit? Wed, 18 May 2005 07:55 Go to previous message
somethings really not right ehre though
i can take 1 and 4 lead out and it doesnt change anything, yet if i block 1 4 carb off it stalls.
if i take out 2 or 3 it stalls.
yet it sounds like it idles fine and drives fine. doesnt sound like its on 2 cylinders at all
Previous Topic:Conversion from US 3SGTE (91) to JAP 3SGTE (94)
Next Topic:incredibly soft brake pedal
Current Time: Wed Oct 28 16:43:45 UTC 2026
Total time taken to generate the page: 0.10259103775024 seconds
