Toymods » Tech & Conversions » Starlet 4E FTE Conversion bugs
fishy417
Caboolture, QLD
May 2005
Starlet 4E FTE Conversion bugs Mon, 16 May 2005 04:29 Go to next message
I have nearly finished the conversion from a ep91 glanza to an ep91 starlet engine is in running idles good, little smoke but hasn't been run for a decent amount of time yet, the only problem i have which is quite bad is that driving it goes to 3k rpm then very very slowly creeps up to about 4 no higher? i merged the glanza instrument cluster into the starlet, and 2 plugs near the ecu and one to it, basically wondering if anyone knows what would cause this, i don't know much at all about the toyota engines
i'm thinking that maybe map sensor or another sensor isn't connected right, oh and i electrically disconnected what i believe is the factory boost controller leaving the pluming to it for now and installed a turbosmart one, but left the both boost settings on min, when its reving up around 3k the first light in the tacho guage comes on, then about 3.5k the second comes, is it meant to come on the soon? feels good up to around 3k then just backs off but does it very smoothly no jerking just slows down? any suggestions, diagrams or ideas would be welcome, thanks
fishy417
Caboolture, QLD
May 2005
Re: Starlet 4E FTE Conversion bugs Mon, 16 May 2005 05:49 Go to previous messageGo to next message
Also heard that you can tune the engine, by shorting certain wires in the diagnostic plug? anyone know anything more about it then that?
10sec_rx7
Syndey
Re: Starlet 4E FTE Conversion bugs Mon, 16 May 2005 05:58 Go to previous messageGo to next message
welcome to the world of starlets, they are a pain to get working correctly
are there any error codes??
all the ones that never work correctly i just put a microtech in them,
best bet is to try
www.austarletclub.com as well
sideshow
Re: Starlet 4E FTE Conversion bugs Mon, 16 May 2005 07:28 Go to previous messageGo to next message
i have wired up afew 4eftes and never had any probs
they are a pain to wire because alot of the body harness runs thru the engine harness
fishy417
Caboolture, QLD
May 2005
Re: Starlet 4E FTE Conversion bugs Mon, 16 May 2005 08:23 Go to previous message
the engine light is on thats the only error i know or, which isn't good, how do i check for engine error codes, it well rev fine in neutral as high as i want, only under load it is limited to 3-4k and seems to only around 5psi when it start hesitating.
Previous Topic:Wolf 3D cold start
Next Topic:Toyota sprinter sunroof fix
Current Time: Sat Oct 24 14:45:24 UTC 2026
Total time taken to generate the page: 0.007498025894165 seconds
