Toymods » Tech & Conversions » AE101 MAP GZE Supercharger shutting off after 5,500rpm - fixed
Phoenix01
Brisbane, Australia
icon7.gif  AE101 MAP GZE Supercharger shutting off after 5,500rpm - fixed Wed, 18 May 2005 02:28 Go to next message
I have a feeling the car has been wired up incorrectly, or there are vaccuum hoses connected up to the wrong things.
The supercharger shuts off after 5,500rpm
Anyone have any idea on where to start?
[Updated on: Tue, 31 May 2005 11:16]
DiZ_
The Eastwood MASSIVE !
Re: AE101 MAP GZE Supercharger shutting off after 5,500rpm Wed, 18 May 2005 13:01 Go to previous messageGo to next message
My mate had the same problem. Sorry to say he has not fixed it.
Things that have been mentioned have been-
Bad fuel causing slight knock
Charger temps / intake temps too high
Chatter from the head in high rpm mistaken as knocking
I'm sure there will be more on that list to add as people reply.
As for some more info , his car ( ae82 with ae101 gze ) was wired correctly and ran fine for over 2 years before he had any problem. He has the Nevo 175mm pulley, stock ECU , front mount cooler , upgraded fuel pump. The cutting of the charger was basically in higher gears such as 3rd and above. On the dyno it was seen that at 5500rpm the power just drops straight down as the charger clutch is released.
Another cause we were looking into was the possiblity that the charger was on the way out. He had a boost leak that took a while to sort yet he drove it anyway , when it was sorted the boost was still at a lower level and the problem seemed a bit worse.
Phoenix01
Brisbane, Australia
Re: AE101 MAP GZE Supercharger shutting off after 5,500rpm Thu, 19 May 2005 06:12 Go to previous messageGo to next message
Thanks for that info.
I've passed that on to the guys I'm paying to fix it, and I've been told they are really good.
So if they find a solution, I'll let you know. Smile
DiZ_
Re: AE101 MAP GZE Supercharger shutting off after 5,500rpm Thu, 19 May 2005 08:10 Go to previous messageGo to next message
That would be great , my mate has kinda lost heart with fixing his and now only drives his other car he bought (stock AE102).
[Updated on: Thu, 19 May 2005 08:11]
Gleno28
Re: AE101 MAP GZE Supercharger shutting off after 5,500rpm Thu, 19 May 2005 08:52 Go to previous messageGo to next message
My 1GGZE seems to do that sometimes, the charger cuts off before the rev limiter, i was thinking that it might be a protection mech for the charger to save the vanes???
Glen.
Phoenix01
Brisbane, Australia
Re: AE101 MAP GZE Supercharger shutting off after 5,500rpm Mon, 30 May 2005 08:19 Go to previous messageGo to next message
Well guys, it seems they found the problem. And its embarrasingly simple. Mind you easier for a workshop with deep pockets, and a dyno, to diagnose and test.
All it was... a faulty knock sensor. Embarassed
Apparently the car has picked up 20kw at the wheels and is running an AFR of 11:1 up high, rather than 9:1. I haven't picked up the car yet, so I'm yet to see what its like for myself.
I'll keep you posted. Smile
ke35 - 4AGZE
Re: AE101 MAP GZE Supercharger shutting off after 5,500rpm Mon, 30 May 2005 08:26 Go to previous messageGo to next message
good result!! Shocked
Phoenix01
Brisbane, Australia
Re: AE101 MAP GZE Supercharger shutting off after 5,500rpm Tue, 31 May 2005 10:37 Go to previous messageGo to next message
The results are in....
The butt dyno says: Very Happy Very Happy Very Happy
bayka
perth
Re: AE101 MAP GZE Supercharger shutting off after 5,500rpm - fixed Tue, 31 May 2005 11:21 Go to previous message
hahaha Wiked Smile
I know what you mean, my belt was slipping when i first put engine in and was only getting like 2psi at higher rpm. Tightened it up and the Butt Meter went of the goddamn scale Surprised
Previous Topic:sort of newbie q's
Next Topic:ae86 Diff con. (strength?)
Current Time: Tue Oct 20 04:55:15 UTC 2026
Total time taken to generate the page: 0.0042068958282471 seconds
