Toymods » Tech & Conversions » quick q. - w58 into ae86, which crossmember?
white86
quick q. - w58 into ae86, which crossmember? Wed, 18 May 2005 06:23 Go to next message
Just a quick question guys and girls,
I did a search but couldn't find an answer.
So what gearbox crossmember to use? I've been told ra65, can anyone confirm? The few wreckers I've called have auto ra65 crossmembers, will these be appropriate?
Thanks heaps,
Dan
ke35 - 4AGZE
Re: quick q. - w58 into ae86, which crossmember? Wed, 18 May 2005 07:06 Go to previous messageGo to next message
good question, i need this answered as well.
x member for ke35 and w58 box???
EvilJack
Sutho/Hills NSW
Re: quick q. - w58 into ae86, which crossmember? Wed, 18 May 2005 23:43 Go to previous messageGo to next message
http://forums.toymods.org.au/index.php?t=msg&t h=11298&rid=1334&S=408fd364e8de5b67c1c4a76 05730e54c&pl_view=&start=0#msg_90676
Purple_Beasty
New Zealand
Re: quick q. - w58 into ae86, which crossmember? Thu, 19 May 2005 10:59 Go to previous messageGo to next message
Will try to get the camera and take pics of my W55 mount for the 18RG/W55 setup in my KE70. Basically the rubber mount is behind the original one by around 2-3 inches.
Callum
no_tofu_speed
Jab what?!!?!
Re: quick q. - w58 into ae86, which crossmember? Thu, 19 May 2005 14:45 Go to previous messageGo to next message
Eviljack, whats a 2 post thread about the bellhousing got to do with the crossmember?? Confused
d-shiznit
W.A
Re: quick q. - w58 into ae86, which crossmember? Thu, 19 May 2005 14:54 Go to previous messageGo to next message
bump
I need to know too!
W57 into ae85
ke35 - 4AGZE
Re: quick q. - w58 into ae86, which crossmember? Thu, 19 May 2005 20:52 Go to previous messageGo to next message
thanks purple beasty,
thatd b good to get a picture.
as for the bellhousing, i already have the converting bellhousing
Henn
Rosanna, Melb
Re: quick q. - w58 into ae86, which crossmember? Thu, 30 June 2005 04:55 Go to previous messageGo to next message
Thought I'd dig this up to see if anyone knows any more.
Is there a factory gearbox crossmember which comes close? Or will I be pulling out the welder?
Hen
Rallystanza
Re: quick q. - w58 into ae86, which crossmember? Thu, 30 June 2005 04:58 Go to previous messageGo to next message
Very curious to know this also as I am doing this in takumi delivered sprinter.
Jezza
ke382TG
Re: quick q. - w58 into ae86, which crossmember? Thu, 30 June 2005 05:11 Go to previous messageGo to next message
I have a W58 in my KE corolla. It uses a custom made crossmember. The issue is mating the w series gearbox mount to the T series x-member. In the case of my car if the two had been mated the gear box would have been forced to sit impossibly high at the back end or the x-member would have to have been lowered, neither were feasible solutions.
This would be a fairly common problem across the above mentioned cars I would suspect (could be wrong?) as a T50 bolted directly up to my car with no mods and used a standard x-member, the w58 didn't even come close with any combo other than on a custom x-member.
For a definitive answer TE72_Turbo could answer in respect to AE chassis cars as he is running a Wxx box in an AE71. Someone could PM him if they want to know.
ke35 - 4AGZE
Re: quick q. - w58 into ae86, which crossmember? Thu, 30 June 2005 06:26 Go to previous messageGo to next message
hey,
do you have any pictures of how the x member looks??
does it just make the w5# sit lower at the rear than it would with the standard x-member??
James
Purple_Beasty
New Zealand
Re: quick q. - w58 into ae86, which crossmember? Thu, 30 June 2005 10:19 Go to previous messageGo to next message
I'm still working on getting a camera.
Hopefully this weekend if it stops raining.
Callum
Grega
melbourne.victoria.austra...
Re: quick q. - w58 into ae86, which crossmember? Thu, 30 June 2005 20:45 Go to previous messageGo to next message
need to know same for my TA22. its rumoured to be a TA22 auto crossmember but, in saying that finding a TA22 auto crossmember is not easy.
i'll probably make my own
[Updated on: Thu, 30 June 2005 20:45]
Henn
Rosanna, Melb
Re: quick q. - w58 into ae86, which crossmember? Fri, 01 July 2005 01:41 Go to previous messageGo to next message
While searching a found a reference on an Australian site that an "import Corolla auto crossmember" was used. Can't remember where, but google found it.
No further information at all though. I will be butchering a T50 crossmember and making it fit.
Hen
Purple_Beasty
New Zealand
Re: quick q. - w58 into ae86, which crossmember? Sat, 09 July 2005 23:26 Go to previous messageGo to next message
Took a while but here you go.
http://img257.imageshack.us/img257/2656/july110ai.th.jpg
http://img257.imageshack.us/img257/3791/july120bg.th.jpg
http://img98.imageshack.us/img98/8727/july137jd.th.jpg
http://img301.imageshack.us/img301/5609/july146nd.th.jpg
http://img39.imageshack.us/img39/5434/july158uc.th.jpg
http://img13.imageshack.us/img13/4901/july160wx.th.jpg
http://img39.imageshack.us/img39/3365/july174go.th.jpg
This was made by a mate when he owned my ute, with a different engine you may want to sit the engine/gearbox back a little. The 18RG needed a bit more firewall clearance.
Callum
ke35 - 4AGZE
Re: quick q. - w58 into ae86, which crossmember? Sun, 10 July 2005 07:50 Go to previous messageGo to next message
ok thanks
Re: quick q. - w58 into ae86, which crossmember? Sun, 10 July 2005 08:06 Go to previous message
Another little note to remember is what engine mounts, and what bellhousing you use - if you're using Toyota engine mounts (with engine on slight lean) and Mr. Dellow's famous mickey-mouse ears housing, you may find the gearbox wants to be on a bit of an angle. I know I did...
Previous Topic:jzz30 differential
Next Topic:note to all ma61 owners considering rear speaker upgrades
Current Time: Thu Oct 15 05:22:29 UTC 2026
Total time taken to generate the page: 0.171550989151 seconds
